\System\SysMenu.dll The specified module could not be found
2013-11-02T19:34:13+00:00
I've just updated to 8.1 and am now getting notification that "...\System\SysMenu.dll The specified module could not be found." I'm not finding anything on the internet about this. Is this a known issue or did I just inform you?
Help is appreciated.
snick5908
2013-11-10T06:33:36+00:00
Microsoft technical support have solved this problem for me. I'm not sure what they did as they logged in remotely to my computer. But if you are having this problem as well it might be worth giving them a call :)
Hi Kim,
Here is the solution:
1st: Download Auto Runs.
Click Here:
http://download.sysinternals.com/files/Autoruns.zip
Link basis: http://technet.microsoft.com/en-us/sysinternals/bb963902.aspx
2nd: Find the yellow highlighted Image Paths that ends with sysmenu.dll. Usually you can locate those image paths from Scheduled Task.
3rd: Right click then delete.
4th: Try to find all yellow highlighted Image Paths that ends with sysmenu.dll from "Everything tabs, delete them.
NOTE: Carefully choose image paths that ends sysmenu.dll only, if you deleted paths that are not high lightened then it might cause some trouble booting your PC.
5th: Reboot Computer
6th: Wait at least 5 minutes to confirm that the issue has been resolved. (sysmenu.dll usually appears within a minute from rebooting the computer. )
Hope it helps :)
J.A. Tan
2015-06-08T08:41:00+00:00
Hi Valentina,
Thank you for posting your query on Microsoft Community.
I would require more information to help you better.
1. Are you facing the same issue?
2. Did you make any changes prior to this issue?
This issue occurs if the system file is corrupted or damaged.
I would suggest you to run System File Checker.
System File Checker is a utility in Windows that allows users to scan for corruptions in Windows system files and restore corrupted files.
https://support.microsoft.com/en-us/kb/929833?wa=wsignin1.0
I would also suggest you to Run DISM or System Update Readiness tool
Windows corruption errors may prevent Windows updates and service packs from installing. For example, an update might not install if a system file is damaged. The DISM or System Update Readiness tool may help you to fix some Windows corruption errors.
https://support.microsoft.com/en-us/kb/947821
Let us know the status of the issue we will be glad to help you further.
137 additional answers
    2013-11-23T12:37:24+00:00
    I have carried out the clean boot as per the support notes above and even with a clean boot the error still appears.
    It appears about 3 minutes after I start up my computer and 3 windows appear with the RunDLL error.
    I have ran the System File Checker tool and received the following message:
    Windows Resource Protection did not find any integrity violations.
    Then, http://technet.microsoft.com/en-us/sysinternals/bb963902
    This issue began when I purchased $279.00 HP IPS LED Backlit 25xi Monitor.
    It came with 1 CD Software to install.
    As KimberleySchrader asked on
    I would really like some help as I purchased my computer recently so it is really annoying to be getting errors like this so early on.   I have HP Pavilion dm4 Beats Audio Laptop ($549) purchased 2 months ago.
    PLEASE HELP.
    2013-11-23T12:42:20+00:00
    KimberleySchrader
    Did you get a fix for your 3 .dll defects?
    I was amazed to read your post because you experienced the exact
    trouble I have been haunted with for 5 weeks.
    Thank you for taking your time to post the issue.
    You gave me hope.
    ******@hotmail.com
    2013-11-27T09:51:32+00:00
    Hi Kim,
    Click Here:
    Hope it helps :)
    J.A. Tan
    The above steps resolved the issue for me!. thanks for posting up the instructions, the error message was starting to drive me up the wall every time i started my laptop.
