\System\SysMenu.dll The specified module could not be found
2013-11-02T19:34:13+00:00
I've just updated to 8.1 and am now getting notification that "...\System\SysMenu.dll The specified module could not be found." I'm not finding anything on the internet about this. Is this a known issue or did I just inform you?
Help is appreciated.
snick5908
2013-11-10T06:33:36+00:00
Microsoft technical support have solved this problem for me. I'm not sure what they did as they logged in remotely to my computer. But if you are having this problem as well it might be worth giving them a call :)
Hi Kim,
Here is the solution:
1st: Download Auto Runs.
Click Here:
http://download.sysinternals.com/files/Autoruns.zip
Link basis: http://technet.microsoft.com/en-us/sysinternals/bb963902.aspx
2nd: Find the yellow highlighted Image Paths that ends with sysmenu.dll. Usually you can locate those image paths from Scheduled Task.
3rd: Right click then delete.
4th: Try to find all yellow highlighted Image Paths that ends with sysmenu.dll from "Everything tabs, delete them.
NOTE: Carefully choose image paths that ends sysmenu.dll only, if you deleted paths that are not high lightened then it might cause some trouble booting your PC.
5th: Reboot Computer
6th: Wait at least 5 minutes to confirm that the issue has been resolved. (sysmenu.dll usually appears within a minute from rebooting the computer. )
Hope it helps :)
J.A. Tan
2015-06-08T08:41:00+00:00
Hi Valentina,
Thank you for posting your query on Microsoft Community.
I would require more information to help you better.
1. Are you facing the same issue?
2. Did you make any changes prior to this issue?
This issue occurs if the system file is corrupted or damaged.
I would suggest you to run System File Checker.
System File Checker is a utility in Windows that allows users to scan for corruptions in Windows system files and restore corrupted files.
https://support.microsoft.com/en-us/kb/929833?wa=wsignin1.0
I would also suggest you to Run DISM or System Update Readiness tool
Windows corruption errors may prevent Windows updates and service packs from installing. For example, an update might not install if a system file is damaged. The DISM or System Update Readiness tool may help you to fix some Windows corruption errors.
https://support.microsoft.com/en-us/kb/947821
Let us know the status of the issue we will be glad to help you further.
137 additional answers
    2015-06-22T09:18:11+00:00
    Rebooting your system is like restarting it, you won’t loss any data when you reboot, and rebooting a computer unloads all device drivers, closes all programs and restarts the operating system. You may need to reboot a computer in the course of normal use or as a troubleshooting step to resolve a problem.
    I would suggest you to refer to the below link:
    How do I restart (reboot) my PC?
    http://windows.microsoft.com/en-US/windows-8/restart-windows
    Hope this information helps and let us know if you have any further queries related to windows we will be glad to help you.
    Thanks.
    2015-06-22T16:27:24+00:00
    snick5908
    I cannot get my computer to stop from shutting down. Every time I turn it on within a minute or so I tells me there was an error and then it shuts down. ITs windows 8.1
    Please help me it is also a acer computer
    2015-06-23T02:13:02+00:00
    From the description, I understand that your computer randomly shutdown.
    1. Does it shut down during any particular activity on the computer?
    2. What is the make and model of the computer?
    3. Do you get any error message/code?
    4. Have you made any changes to the computer prior to this issue?
    I would recommend you to follow the below given methods and check if it fixes the issue.
    Method 1: Run System Maintenance Troubleshooter
    a. Press Windows+R and type Troubleshooting.
    b. Select Troubleshooting.
    c. Select view all on the top left corner.
    d. Run System Maintenance Troubleshooter.
    Method 2: Check in Safe Mode
    Safe Mode is useful for troubleshooting problems with programs and drivers that might not start correctly or that might prevent Windows from starting correctly. If a problem doesn't reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes. If a recently installed program, device, or driver prevents Windows from running correctly, you can start your computer in safe mode and then remove the program that's causing the problem. For more information about troubleshooting problems in safe mode
    http://windows.microsoft.com/en-us/windows-8/windows-startup-settings-safe-mode
    Hope this information helps and let us know the status of the issue we will be glad to help you further.
    Thanks.
