\System\SysMenu.dll The specified module could not be found
2013-11-02T19:34:13+00:00
I've just updated to 8.1 and am now getting notification that "...\System\SysMenu.dll The specified module could not be found." I'm not finding anything on the internet about this. Is this a known issue or did I just inform you?
Help is appreciated.
snick5908
2013-11-10T06:33:36+00:00
Microsoft technical support have solved this problem for me. I'm not sure what they did as they logged in remotely to my computer. But if you are having this problem as well it might be worth giving them a call :)
Hi Kim,
Here is the solution:
1st: Download Auto Runs.
Click Here:
http://download.sysinternals.com/files/Autoruns.zip
Link basis: http://technet.microsoft.com/en-us/sysinternals/bb963902.aspx
2nd: Find the yellow highlighted Image Paths that ends with sysmenu.dll. Usually you can locate those image paths from Scheduled Task.
3rd: Right click then delete.
4th: Try to find all yellow highlighted Image Paths that ends with sysmenu.dll from "Everything tabs, delete them.
NOTE: Carefully choose image paths that ends sysmenu.dll only, if you deleted paths that are not high lightened then it might cause some trouble booting your PC.
5th: Reboot Computer
6th: Wait at least 5 minutes to confirm that the issue has been resolved. (sysmenu.dll usually appears within a minute from rebooting the computer. )
Hope it helps :)
J.A. Tan
2015-06-08T08:41:00+00:00
Hi Valentina,
Thank you for posting your query on Microsoft Community.
I would require more information to help you better.
1. Are you facing the same issue?
2. Did you make any changes prior to this issue?
This issue occurs if the system file is corrupted or damaged.
I would suggest you to run System File Checker.
System File Checker is a utility in Windows that allows users to scan for corruptions in Windows system files and restore corrupted files.
https://support.microsoft.com/en-us/kb/929833?wa=wsignin1.0
I would also suggest you to Run DISM or System Update Readiness tool
Windows corruption errors may prevent Windows updates and service packs from installing. For example, an update might not install if a system file is damaged. The DISM or System Update Readiness tool may help you to fix some Windows corruption errors.
https://support.microsoft.com/en-us/kb/947821
Let us know the status of the issue we will be glad to help you further.
137 additional answers
    2015-06-19T04:09:09+00:00
    After I did all of the steps, the error came up again after a while. Any more suggestions?
    2015-06-19T10:22:02+00:00
    @VegasBlog
    See this free, multi-step removal guide: http://malwaretips.com/blogs/snap-do-toolbar-removal/[http://malwaretips.com/blogs/remove-sysmenu-dll-virus/](http://malwaretips.com/blogs/remove-sysmenu-dll-virus/)
    In case you can't do step 1, move on with the next steps.
    If need be, run multiple scans with each of the tools and also reboot multiple times.
    Cheers,
    J
    2015-06-20T12:59:05+00:00
    I've done all the steps and I have a question about reboot. Is it just restart or it erases all the material in the pc? I've searched about it and some say it's restart and some say that other thing. I need an answer from you.
    But I don't have that kind of problem with windows 8.1. I have windows 7 unltimate and one day it popped
    Since that day everytime I started my pc this notofication kept popping and not only one but two of a kind.
