\System\SysMenu.dll The specified module could not be found
2013-11-02T19:34:13+00:00
I've just updated to 8.1 and am now getting notification that "...\System\SysMenu.dll The specified module could not be found." I'm not finding anything on the internet about this. Is this a known issue or did I just inform you?
Help is appreciated.
snick5908
2013-11-10T06:33:36+00:00
Microsoft technical support have solved this problem for me. I'm not sure what they did as they logged in remotely to my computer. But if you are having this problem as well it might be worth giving them a call :)
Hi Kim,
Here is the solution:
1st: Download Auto Runs.
Click Here:
http://download.sysinternals.com/files/Autoruns.zip
Link basis: http://technet.microsoft.com/en-us/sysinternals/bb963902.aspx
2nd: Find the yellow highlighted Image Paths that ends with sysmenu.dll. Usually you can locate those image paths from Scheduled Task.
3rd: Right click then delete.
4th: Try to find all yellow highlighted Image Paths that ends with sysmenu.dll from "Everything tabs, delete them.
NOTE: Carefully choose image paths that ends sysmenu.dll only, if you deleted paths that are not high lightened then it might cause some trouble booting your PC.
5th: Reboot Computer
6th: Wait at least 5 minutes to confirm that the issue has been resolved. (sysmenu.dll usually appears within a minute from rebooting the computer. )
Hope it helps :)
J.A. Tan
2015-06-08T08:41:00+00:00
Hi Valentina,
Thank you for posting your query on Microsoft Community.
I would require more information to help you better.
1. Are you facing the same issue?
2. Did you make any changes prior to this issue?
This issue occurs if the system file is corrupted or damaged.
I would suggest you to run System File Checker.
System File Checker is a utility in Windows that allows users to scan for corruptions in Windows system files and restore corrupted files.
https://support.microsoft.com/en-us/kb/929833?wa=wsignin1.0
I would also suggest you to Run DISM or System Update Readiness tool
Windows corruption errors may prevent Windows updates and service packs from installing. For example, an update might not install if a system file is damaged. The DISM or System Update Readiness tool may help you to fix some Windows corruption errors.
https://support.microsoft.com/en-us/kb/947821
Let us know the status of the issue we will be glad to help you further.
137 additional answers
    2014-07-21T14:39:44+00:00
    Thank you !!!. This has apparently fixed the problem. I talked to the "Answer Desk" three times and could not get any kind of satisfaction. I am not only talking about communication issues (which are, unfortunately, common enough that they are expected) but the knowledge of the issue and their unwillingness to admit it. anyway, now that I have vented, thanks again.
    2014-07-30T21:20:14+00:00
    Let's analyze and identify the cause of the issue.
    1. When do you get this error message?
    2. Does this issue occur when you launch a specific program or randomly?
    Place the computer in clean boot and check for the issue.
    How to perform a clean boot to troubleshoot a problem in Windows Vista, Windows 7, or Windows 8
    http://support.microsoft.com/kb/929135
    Note: Once you are done with clean boot, please follow the section ‘How to reset the computer to start as usual after troubleshooting with clean boot’ under ‘more information’ in the article to put your computer back to normal startup.
    Hope this information helps. Reply with the status so that we could help you further.
    This worked like a charm, many thanks for your help Tan.
    2014-08-04T15:36:59+00:00
    www.freefixer.com works at removing this darned problem.
    It took me a while to find this.
    W
