Windows 8 occasional no sound problem. The device is being used by another application.
2014-07-10T14:01:39+00:00
I have been having sound problems with the speakers on an HP Ultrabook running Windows 8. Occasionally the laptop speakers stop working. When this occurs, I go to Control Panel>Sound, select the speakers(only one set to select), select Configure and Test. After selecting Test, I receive the message Device In Use. The device is being used by another application. Please close any devices that are playing audio to this device and then try again. I've gone to Properties for the speakers, Advanced tab and unchecked option "Allow applications to take exclusive control of this device". I've also used Run sndvol to try to determine the application, but it only shows Device:Speakers/HP and Applications:System Sounds.
The only way I've been able to get the speakers to work is to reboot or disable and enable the driver for the IDT High Definition Audio CODEC. Does anyone know of a way to determine the application causing the problem? Thanks in advance for your help.
Gary
2014-07-14T10:32:25+00:00
Go to device manager, select the audio device/driver and click scan for hardware changes.
voiala! sounds stupid but works for me.
2014-07-16T13:48:58+00:00
On the HP Community forum an HP tech found that uninstalling Microsoft update KB2962407 should fix the problem.  This update has a fix that states "Shortened battery life when an idle audio device is not turned off on a computer running Windows".  I installed this update on June 19.  I don't have any July updates installed, so uninstalling July updates may not fix the problem.
84 additional answers
    2014-07-15T23:33:49+00:00
    I'm having this problem too. The two fixes worked for a small amount of time but it's back to silent again. Hope it's fixed soon. I
    2014-07-16T06:52:02+00:00
    I went in an uninstalled the windows updates and it's good as new again. So far anyways.
    http://windows.mercenie.com/windows-8/how-to-install-and-uninstall-updates-in-windows-8/
    2014-07-16T07:15:58+00:00
    I also experience the problem since the latest update.
    But I found a way to make mine work: after turning on the computer, but before going online (before establishing my cable internet connection) I start playing Game of Thrones from my hard drive. This somehow solves the problem for me: I guess it doesn't let the whatever that is otherwise blocking the audio take effect. Probably works with any other video too :) .
    Beautiful Windows-woodoo solution: I am very proud :) .
