Windows 8 occasional no sound problem. The device is being used by another application.
2014-07-10T14:01:39+00:00
I have been having sound problems with the speakers on an HP Ultrabook running Windows 8. Occasionally the laptop speakers stop working. When this occurs, I go to Control Panel>Sound, select the speakers(only one set to select), select Configure and Test. After selecting Test, I receive the message Device In Use. The device is being used by another application. Please close any devices that are playing audio to this device and then try again. I've gone to Properties for the speakers, Advanced tab and unchecked option "Allow applications to take exclusive control of this device". I've also used Run sndvol to try to determine the application, but it only shows Device:Speakers/HP and Applications:System Sounds.
The only way I've been able to get the speakers to work is to reboot or disable and enable the driver for the IDT High Definition Audio CODEC. Does anyone know of a way to determine the application causing the problem? Thanks in advance for your help.
Gary
2014-07-14T10:32:25+00:00
Go to device manager, select the audio device/driver and click scan for hardware changes.
voiala! sounds stupid but works for me.
2014-07-16T13:48:58+00:00
On the HP Community forum an HP tech found that uninstalling Microsoft update KB2962407 should fix the problem.  This update has a fix that states "Shortened battery life when an idle audio device is not turned off on a computer running Windows".  I installed this update on June 19.  I don't have any July updates installed, so uninstalling July updates may not fix the problem.
84 additional answers
    2014-08-14T13:29:11+00:00
    Steve,
    There are two other things to try since removal of update KB2962407 did not fix your sound problem.
    1. Go to Control Panel>Sound and on the Playback tab select your speakers.  Click on Properties and select the Advanced tab.  On this page you should see the following statement "Allow applications to take exclusive control of this device".  If the statement is checked, uncheck it.
    2. Dr. Pfeiffer's recommendation to update the driver for Realtek sound cards has fixed the problem for a lot of people.
    Hope this helps.
    Gary
    2014-08-14T14:35:07+00:00
    I face the same issue and it works if I find audiodg from task manager and end the task. Try this might work. It works for me.
    2015-06-25T07:09:32+00:00
    Hey everyone i had the same problem.
    Just open task manager(in windows 8 and 8.1) and end the task name "Windows audio device graph isolation" and in sound-playback devices-advance tab(in speaker properties) untick allow applications to take exclusive control of this device.You will get your device working.
