How can I disable the unsafe volume warning?
2013-11-06T12:28:29+00:00
I usually have my laptop's system volume at 80% and plugged into speakers which I can adjust, but since updating to windows 8.1 I keep noticing that every time I turn my laptop on while plugged into the speakers it automatically lowers and limits my volume to about 40% and when I try to turn it up a large banner warns me that any higher might be unsafe for my ears asking am I sure I want to do this.
It's very annoying to get this every day, and I can't seem to find a way to disable the warning permanently.
    2016-07-19T19:28:47+00:00
    This didn't work for me on a Samsung Notebook 9 -- after Step 5, there's no sound device installed at all, so could not find and update any driver. Was able to revert just by changing the Properties so that System can make changes.
    2016-08-19T17:44:15+00:00
    Not personally replying to you but to the thread in general... Why don't they have a "reply to thread" button is beyond me.
    In any case, just sharing my experience as it may help someone.  I tried to use the non-Realtek drivers from windows but it isn't fully compatible as my headphone jack doesn't work any more.  I have a Samsung NP700Z7C btw.  So I had to go back to the Realtek drivers.  However, when I went to Update the Realtek drivers, I noticed that my old Win 7 drivers were still there (I did an upgrade to Win 10) because I see the date is 2012.  So I selected that, and bam, no more nag pop up, and everything, including the headphone jacks, work!
    Procedures:
    Open Device Manager, open Sound, video and game controllers, right click on Realtek High Definition Audio and select Update Driver Software. Then "Browse my computer for driver software", then "Let me pick form a list of device drivers on my computer."
    Then I selected the driver with date 2012.  However, if you upgraded from windows 8, and you had the nag there, then I don't know if it will work.  I then Deny System access to the Realtek folder in Program Files so windows/SWupdate can't update it.
    The Realtek driver version is: 6.0.1.6716 [8/28/2012]
    Hope this helps someone!
    2016-09-26T18:25:44+00:00
    I seem to have this issue on my linx 1010B windows 10 tablet. The flippin' prompt does get very annoying when I need to use my device as an source device. As like you, I am also a sound engineer, perhaps the way around this is to use an external usb soundcard, however, this proves very annoying as the device should
    be able to output a modest signal independently. I have not had this problem on either my lenovo laptop, or 2 of my main rendering pc's.
    Any luck?
    2016-10-01T11:58:44+00:00
    Some info about my system:
    Samsung Series 7, Win10, Realtek Audio Drivers
    Anytime adjusting my headset volume past 40 I'd get a "this is dangerous" popup, real annoying when playing fullscreen games.
    I solved this issue by going to All settings -> System -> Notifications & Actions -> Realtek HD Audio Manager
    and turned display notifications from this app to OFF.
    Another way you might do this is by going to Sound -> Playback Options, and selecting a different default playback device if you have another driver installed.
    Hope that helps.
    2016-12-17T05:04:23+00:00
    Hi Gemma,
    Do you face this volume issue only when the speaker is plugged in?
    What is the make and model of the computer and the speaker?
    Have you installed any third party software to manage the audio options?
    If the volume keeps resetting to 40% every time you start the computer, it could be due to some incorrect settings due to any third party audio management applications or due to a driver issue.
    I would suggest you to first disconnect the speaker to check if you are facing this issue only when the speakers are plugged in.
    Method 1:
    If you have installed any third party audio management applications, I would suggest you to first uninstall them and then check if the issue persists.
    Method 2:
    If the above steps didn’t help or if you haven’t installed any third party audio management applications, then I would suggest you to reinstall the driver and check. Refer to these steps:
    a)      Press Windows key + X, select Device manager.
    b)      Locate the audio device and right click on it to select properties.
    c)       In the driver tab, click on ‘uninstall’ to uninstall the current audio driver.
    d)      Restart the computer.
    e)      Now, windows would have loaded with the generic audio driver, check if the issue persists.
    f)       If yes, visit the manufacturer’s website to download and install the latest driver and check.
    Try these steps and let us know the results. We’d be happy to help if you need any further assistance.
    Bennet Martin is either an unmitigated idiot, or a cyberclone of a human being displaying terminal willful ignorance.
