How can I disable the unsafe volume warning?
2013-11-06T12:28:29+00:00
I usually have my laptop's system volume at 80% and plugged into speakers which I can adjust, but since updating to windows 8.1 I keep noticing that every time I turn my laptop on while plugged into the speakers it automatically lowers and limits my volume to about 40% and when I try to turn it up a large banner warns me that any higher might be unsafe for my ears asking am I sure I want to do this.
It's very annoying to get this every day, and I can't seem to find a way to disable the warning permanently.
    2016-04-20T12:14:19+00:00
    I had the same problem,
    What's happening is that the Windows update service is updating your driver to the latest Realtek 6.0.1.7xxx. The latest driver has the irritating EU safety warning.
    Solution:
    Download 6.0.1.6699 (for instance, worked for me):
    http://wisedriverupdate.com/Samsung\_NP530U3C\_A07US\_Realtek\_Audio\_Driver\_6\_0\_1\_6699\_for\_Windows\_7.html
    Then follow this tutorial which shows how to block hardware updates, inspecific the Local Policy Group Editor:
    http://www.makeuseof.com/tag/take-back-control-driver-updates-windows-10/
    It should be relatively straightforward, but just to add:
    Right click on the Realtek Audio device, under Sound video, audio and game Drivers in Device Manager.
    Then go to Hardware IDs, copy and paste the two (or more IDs) into Local Policy Group Editor.
    1. Make sure to get the Hardware ID before uinstalling Realtek 6.0.1.7xxx, save them in a txt file.
    2. Uninstall Realtek, restart computer
    3. Reinstall Realtek 6.0.1.6xxx, DO NOT RESTART!
    4. Then Paste in the hardware IDs and enable Local Policy Group Editor. Now you've locked 6.0.1.6xxxx
    5. Restart Device
    6. Enjoy
    Hope that works!
    2016-04-20T12:25:28+00:00
    This method works, but you are just using the native Sound Driver.
    If you still want to use Realtek, but without the annoying message, see my solution below.
    2016-04-20T12:26:40+00:00
    5. Restart Device
    6. Enjoy
    Hope that works!
    2016-06-15T19:42:18+00:00
    There is absolutely NO THIRD PARTY software involved in this; it's a Microsoft "big brother" programming thing.
    I upgraded from Win 7 to Win 10, and I use my laptop as my home computer. I always have headphones on, so as not to disturb anyone else in the house (I pretty much live in my room). Because of this, I too constantly have to click off the "high volume" warning--it is always fixed-set by Win 10 to 42%.  What is really annoying is, if I happen to lock my screen if I leave the house, or close the lid, when I return and log back in, unlock the screen--whatever--I have to RESET the volume because it went BACK to the 42%! It is incredibly ANNOYING.
    2016-07-02T20:55:54+00:00
    I had this same problem. Found out it is a Realtek driver issue, not Microsoft. So if you have Realtek loaded anywhere on your computer--i.e. systems folder, that is your bad boy.
    Turns out it has to do with some EU regulation standards and it really sucks! I found the fix and solution on this page: http://www.noach.one/technotip/idiotic-realtek-audio-drivers/
    That should do it, it worked for me.
