I had this problem when I was playing a game called "Call of Duty 4: Modern Warfare". My PC suddenly shut down while I was playing the game, and after that, I booted and that **** of an error came up. And it goes in loops. The first time it happened to me, I just let my laptop rest for a while, thinking it's just an overheating issue. But the next day, it is still restarting in loops. I tried to boot on the recovery CD of Windows 8.1 but still no hope. The error still comes up. The next moment, I really got irritated and removed my laptop battery. And I remembered that there is something that I read in the past that if your PC have problem, refresh it by doing this: 1.) Remove the battery of your laptop. 2.) Do not connect AC Power Supply/ Charger. 3.) Press the power button for like 20 seconds or more, if you are that kind of angry. 4.) Start the laptop without battery by powering it up via AC. These magical steps did the trick. The second time it happened to me when my PC crash again, and the restart loop happened, this trick really worked. Very helpful. I remember this trick is like deleting your BIOS memory or something. I did not remember anything. So, I just want to share my experience with my laptop. By the way, my laptop is an Acer 4755G, with Windows 8.1 installed on it. Good luck Guys! (Filipino here! Hohohoho.)
Windows 8: "Your PC ran into a problem and needs to restart, we're just collecting some error info, and then we'll restart for you."
The message in the title appears on my screen every time I turn my Samsung ATIV Book 9 Lite on. This is after I tried upgrade from Windows 8 to Windows 8.1 last night. I went to sleep whilst 8.1 was downloading and forgot to plug my laptop in, it therefore ran out of battery. When I woke up and restarted my computer the message appeared. It restarts and the message is there again, it is a continuous loop, I can't get past this message and so I cannot even log in. I also haven't got a reboot dvd/usb stick and the computer wont go into safe mode.
I don't know what to do! HELP!!!
Hi Edward,
This could be due to the power failure on the Laptop during the installation of Windows 8.1 update on the computer. It seems that you are getting a "Blue Screen Error” on the computer. These type errors usually occurs when a serious problem causes Windows 8 to shut down or restart unexpectedly. There are multiple reasons why this type of errors occurs on the computer. In this case, the issue could be due to the damaged or corrupted System Files on the computer.
Since you are unable to boot the computer and it is in a restart loop, you may have to create a bootable Windows 8 installation media and then perform an Automatic Repair. To create a Windows 8 bootable disk/media, please refer to the article given below and follow the instructions given in it:
Create installation media for Windows 8
Once after creating the installation disc, you may boot the computer from the disc that you have just created and then follow the instructions given below to perform an Automatic Repair of Windows 8.
Method 1: Perform an Automatic Repair of Windows 8 using the installation media.
a) Contact the computer manufacturer to change the boot order of the computer. You will have to change the boot device to CD/DVD drive and then boot from the Windows 8 installation disc.
b) In the “Windows Setup” dialog box that appears, set the Time and currency format, Keyboard or input method and the language to install and then click “Next”.
c) Click on “Repair your computer” from the lower left corner.
d) From the “Choose an option screen”, click on “Troubleshoot”.
e) Click “Advanced Options” in the “Troubleshoot” screen.
f) In the “Advanced Options” screen, click “Automatic Repair”.
g) Follow the on-screen instructions to complete the Automatic Repair.
If that doesn’t work, then try the next method to perform a System Restore using the Windows 8 bootable disk and check if you are able to boot the computer to the Start Screen successfully.
Method 2: Perform a System restore and check.
To perform a System Restore, follow these instructions and check:
f) In the “Advanced Options” screen, select “System Restore”.
g) Follow the on screen instructions to restore the computer to an earlier state when the computer was working fine.
Hope this is helpful. Please get back to us with the results.
50 additional answers
2014-01-20T16:56:21+00:00 this also happens with my hp pavilion 15 notebook, when i try to upgrade window 8 to window 8.1. When the computer starts, hold 'F11', and it should appear with a recovery mode. Choose your keyboard layout, and it should show out 'continue to use window 8'. It should restart again and there should be a display where you are able to choose an earlier system restore and it should take couple of minutes to restore. ( a black screen with logo does not mean the laptop is broken).
window 8 is not good since the system does not show any F key buttons to do BIOS, compare to other window 7, vista, xp, you do see them at the beginning of the start up.
2014-02-21T03:23:08+00:00 Thanks Bro
2014-03-05T20:47:06+00:00 I had almost the same problem on a Samsung NP270E5E Laptop that a friend was having trouble with, however the 'F4' option didn't even work, BIOS access was disabled - everything was locked down by UEFI - with windows stuck in a boot loop.
In the end what I had to do was remove the power and battery, unscrew the cover on the back, remove the drive, and power up the computer without the battery on AC power only - the BIOS then detects the problem with boot and offers the F4 recovery option (even though this was previously locked out by UEFI) - hit the F4 key, then quickly yank the power cable (before it can get to the bios boot) - reconnect the hard disk, put back in the battery and then boot - bingo, the device boots right in to the Samsung recovery, at that point you can restore the system.
