Chrome and Firefox browsers not compatible with Windows 8.1 update
2013-10-18T17:15:32+00:00
I have just installed the new windows 8.1 update today (18th October) and found that both chrome and firefox do not work. (I had the latest versions installed which worked fine with windows 8.) I've even tried installing chrome 4.1 beta and the "unstable" chrome 5... I've made sure that they (chrome and firefox) are 'allowed' through the firewall, but still can't get them to work. Both web browsers open and look like they're working, but when I try to open a website chrome says it can't connect to the internet and firefox just remains on the start page. I know my internet works fine as internet explorer works and so does the app store. Any help on this would be appreciated! Thank you
2013-10-18T17:52:13+00:00
There's a solution by ianself on mozilla's support forum and it worked for me! It fixed both my chrome and firefox browsers.
  1. Type "cmd.exe" into Search and then right-click on Command Prompt****to select 'Run as administrator'
  2. Type "netsh winsock reset" into Command Prompt, and then press Enter
  3. Restart PC
 source: https://support.mozilla.org/en-US/questions/974612#answer-491242
45 additional answers
    2015-05-08T08:47:51+00:00
    DanMu - I too have a brand new computer and installed Firefox because of the "crashes" with IE -- well, Firefox doesn't perform correctly either .. Windows 8.1 isn't what it's "cracked up" to be in my book.
    2015-07-31T21:27:58+00:00
    I just got windows 10 and I have notice that chrome doesn't work on it. How do I fix this?
    2015-09-13T20:53:27+00:00
    Thank you so much for this fix..I can't tell you how grateful I am that you posted it! I work from home and if not for this solution, I could have lost my job.
    So again,  Thank you so very much!
    2015-09-23T23:05:33+00:00
    Thank you for your help,  It worked for me also.
