Chrome and Firefox browsers not compatible with Windows 8.1 update
2013-10-18T17:15:32+00:00
I have just installed the new windows 8.1 update today (18th October) and found that both chrome and firefox do not work. (I had the latest versions installed which worked fine with windows 8.) I've even tried installing chrome 4.1 beta and the "unstable" chrome 5... I've made sure that they (chrome and firefox) are 'allowed' through the firewall, but still can't get them to work. Both web browsers open and look like they're working, but when I try to open a website chrome says it can't connect to the internet and firefox just remains on the start page. I know my internet works fine as internet explorer works and so does the app store. Any help on this would be appreciated! Thank you
2013-10-18T17:52:13+00:00
There's a solution by ianself on mozilla's support forum and it worked for me! It fixed both my chrome and firefox browsers.
  1. Type "cmd.exe" into Search and then right-click on Command Prompt****to select 'Run as administrator'
  2. Type "netsh winsock reset" into Command Prompt, and then press Enter
  3. Restart PC
 source: https://support.mozilla.org/en-US/questions/974612#answer-491242
45 additional answers
    2014-04-28T21:46:40+00:00
    Thank You SO much. nothing was working until now. Finally a solution that works, thank you, its greatly appreciated.
    2014-04-09T13:20:42+00:00
    I'm sorry to hear that some of you are still suffering from this problem. Unfortunately, I know nothing of how to resolve it, other than the fix I found/shared. Hopefully another thread sheds more light on the matter, and if so do share the fix :)
    All the best,
    Caz
    2014-04-09T12:07:58+00:00
    After updating to windows 8.1 my browsers didn't work but thank you very much caicah for sharing this "fixed" and also to ianself of mozilla's support forum...
    It works on my Lenovo ideapad N586.... thumbs up! All is running now smoothly...
    2014-02-23T17:56:03+00:00
    Having updated from Windows 8 to to 8.1. only to find myself unable to do any browsing on the web afterwards, I was about to give up. After searching for solutions for over 24 hrs on another computer, I found and tried this suggestion. It totally worked for Firefox, IE and Chrome, all at once!! I am so, so relieved! Thanks!
