Two finger right click does not work
2013-10-18T16:17:22+00:00
I recently installed Windows 8.1 and the two finger right click gesture on my touchpad stopped working. Before the update it was working fine. I do not know how to fix it.
2014-01-21T14:44:09+00:00
Hey, I personally found this way for the 2 Finger-click to work out after searching for 4-5 months ( I am assuming your touchpad is Synaptics; as mine is) :
  1. To re-enable two finger tap, press Windows key + R, enter "regedit" then press enter, and on the left pane browse to the following location:
HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadPS2
  1. In the right pane, double click on 2FingerTapAction and change the value to a "2" (Hexadecimal) for right click, or a "4" (Hexadecimal) for middle click.
  2. Double click on 2FingerTapPluginID and clear any value it may have.
  3. In the right pane, find the MultiFingerTapFlags key and change it from a 2 to a 3.
  4. Additionally, if you want to enable three finger tap for middle click, double click on 3FingerTapAction and change the value to a "4", also clear any value for 3FingerTapPluginID and set 3FingerTapPluginActionID to "0".
  5. Restart your PC and you can see the changes well enough.
Note: You should be careful enough while changing the keys in the Registry, as any deletion or wrong entry may create problems in running Windows.
Good Luck!
2014-02-02T16:45:55+00:00
To the above 'Jeet Das's answer, I'd like to add that on my Lenovo IdeaPad Y500, the settings that needed to be changed were under
HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadSMB2c
Thanks Jeet!
49 additional answers
    2013-10-28T08:29:31+00:00
    Here's how to fix it: http://www.intowindows.com/how-to-enable-two-finger-tap-for-right-click-in-windows/
    This is not really a fix but a workaround. As the article says you should not have to use this program if your touchpad driver already supports this function. Clearly the drivers previously supported this function and can only have been removed at the request of Microsoft.
    So come on MS own up to your mistake and get it rectified!
    2013-10-29T02:05:44+00:00
    If the touchpad is from Cypress then this issue might be due to CyTpService not getting migrated correctly on upgrade.
    Can you open up the device manager and see if there is a "Cypress Input Device" node? If there is, can you also open up registry and see HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\CyTpService exists?
    Let me know so I can provide instruction to instantiate the service.
    Eliyas
    2013-10-30T01:54:28+00:00
    I have HP ENVY 17-j005tx Notebook and the same issue! very frustrating  - That's it going back to windows 8
