Two finger right click does not work
2013-10-18T16:17:22+00:00
I recently installed Windows 8.1 and the two finger right click gesture on my touchpad stopped working. Before the update it was working fine. I do not know how to fix it.
2014-01-21T14:44:09+00:00
Hey, I personally found this way for the 2 Finger-click to work out after searching for 4-5 months ( I am assuming your touchpad is Synaptics; as mine is) :
  1. To re-enable two finger tap, press Windows key + R, enter "regedit" then press enter, and on the left pane browse to the following location:
HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadPS2
  1. In the right pane, double click on 2FingerTapAction and change the value to a "2" (Hexadecimal) for right click, or a "4" (Hexadecimal) for middle click.
  2. Double click on 2FingerTapPluginID and clear any value it may have.
  3. In the right pane, find the MultiFingerTapFlags key and change it from a 2 to a 3.
  4. Additionally, if you want to enable three finger tap for middle click, double click on 3FingerTapAction and change the value to a "4", also clear any value for 3FingerTapPluginID and set 3FingerTapPluginActionID to "0".
  5. Restart your PC and you can see the changes well enough.
Note: You should be careful enough while changing the keys in the Registry, as any deletion or wrong entry may create problems in running Windows.
Good Luck!
2014-02-02T16:45:55+00:00
To the above 'Jeet Das's answer, I'd like to add that on my Lenovo IdeaPad Y500, the settings that needed to be changed were under
HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadSMB2c
Thanks Jeet!
49 additional answers
    2013-10-25T08:17:31+00:00
    As this affects multiple vendors, it would seem logical that the removal of the 2-finger tap (only allowing a 2-finger click) was only as a result of the companies responding to a Microsoft directive. It seems disingenuous for Microsoft to blame the 3rd party vendors.
    2013-10-27T22:01:38+00:00
    I have HP envy sleekbook. I too have the same issue. Stopped working a few days after working with 8.1
    Its seems like a bug in 8.1. I loved the feature. Cant get rid of it.
    Microsoft, pls solve it.
    2013-10-28T01:09:57+00:00
    Here's how to fix it:
    http://www.intowindows.com/how-to-enable-two-finger-tap-for-right-click-in-windows/
    Make sure on the first tab, you start on windows (so you don't have to open/run the program every time, and on the second tab that you disable scrolling (as long as your two finger scrolling is working) or you'll get really **** scrolling because two different programs are telling it to do the same thing at the same time.
