Two finger right click does not work
2013-10-18T16:17:22+00:00
I recently installed Windows 8.1 and the two finger right click gesture on my touchpad stopped working. Before the update it was working fine. I do not know how to fix it.
2014-01-21T14:44:09+00:00
Hey, I personally found this way for the 2 Finger-click to work out after searching for 4-5 months ( I am assuming your touchpad is Synaptics; as mine is) :
  1. To re-enable two finger tap, press Windows key + R, enter "regedit" then press enter, and on the left pane browse to the following location:
HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadPS2
  1. In the right pane, double click on 2FingerTapAction and change the value to a "2" (Hexadecimal) for right click, or a "4" (Hexadecimal) for middle click.
  2. Double click on 2FingerTapPluginID and clear any value it may have.
  3. In the right pane, find the MultiFingerTapFlags key and change it from a 2 to a 3.
  4. Additionally, if you want to enable three finger tap for middle click, double click on 3FingerTapAction and change the value to a "4", also clear any value for 3FingerTapPluginID and set 3FingerTapPluginActionID to "0".
  5. Restart your PC and you can see the changes well enough.
Note: You should be careful enough while changing the keys in the Registry, as any deletion or wrong entry may create problems in running Windows.
Good Luck!
2014-02-02T16:45:55+00:00
To the above 'Jeet Das's answer, I'd like to add that on my Lenovo IdeaPad Y500, the settings that needed to be changed were under
HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadSMB2c
Thanks Jeet!
49 additional answers
    2015-11-03T04:33:00+00:00
    That was the perfect solution for my dell inspiron 5537 ,how did you find it?
    2015-11-03T21:05:25+00:00
    I had the same issue with my Ideapad U430 after in installing Win10. Installing the latest Win10 Synaptics driver from the Lenovo support site did not solve the issue. I tried the Registry edit suggested by Jeet Das). There are a number of Registry entries for Synaptics and 2FingerTapAction. There should be REG_DWORD key with that name with value (2) and a 2FingerTapPluginID string key with value SynTP (I think - although the above suggests that it might work without the 'SynTP'). The question was, where to make the change? I added the above in a number of locations, including the one suggested by Jeet Das, but none seemed to make a difference. Finally, I saw one I hadn't changed yet under HKEY_LOCAL_MACHINE\SOFTWARE\Synaptics\SynTP\Win10. As soon as I had changed the 2FingerTapAction key value to (2) and had restarted my computer, the problem was solved!
    I can't guarantee that the other entries at the other locations had nothing to do with this, so if the above doesn't work for you, try doing the same under
    HKEY_LOCAL_MACHINE\SOFTWARE\Synaptics\SynTP\Defaul
    HKEY_CURRENT_USER\SOFTWARE\Synaptics\SynTP\TouchPa
    and
    Good luck!
    Wim
    2015-12-26T02:19:57+00:00
    I followed the steps shown in the video but didn't work for me..
    Instide I did it with TouchPadSMB2c "not"TouchPadPS2"It's underTouchPadPS2" root..
    and it works for me now.
    Thanks for sharing anyway.
