Two finger right click does not work
2013-10-18T16:17:22+00:00
I recently installed Windows 8.1 and the two finger right click gesture on my touchpad stopped working. Before the update it was working fine. I do not know how to fix it.
2014-01-21T14:44:09+00:00
Hey, I personally found this way for the 2 Finger-click to work out after searching for 4-5 months ( I am assuming your touchpad is Synaptics; as mine is) :
  1. To re-enable two finger tap, press Windows key + R, enter "regedit" then press enter, and on the left pane browse to the following location:
HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadPS2
  1. In the right pane, double click on 2FingerTapAction and change the value to a "2" (Hexadecimal) for right click, or a "4" (Hexadecimal) for middle click.
  2. Double click on 2FingerTapPluginID and clear any value it may have.
  3. In the right pane, find the MultiFingerTapFlags key and change it from a 2 to a 3.
  4. Additionally, if you want to enable three finger tap for middle click, double click on 3FingerTapAction and change the value to a "4", also clear any value for 3FingerTapPluginID and set 3FingerTapPluginActionID to "0".
  5. Restart your PC and you can see the changes well enough.
Note: You should be careful enough while changing the keys in the Registry, as any deletion or wrong entry may create problems in running Windows.
Good Luck!
2014-02-02T16:45:55+00:00
To the above 'Jeet Das's answer, I'd like to add that on my Lenovo IdeaPad Y500, the settings that needed to be changed were under
HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadSMB2c
Thanks Jeet!
49 additional answers
    2014-09-21T11:05:09+00:00
    Thanks Jeet!
    This works great but can confirm I needed to change the settings under HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadSMB2c
     changes made under HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadPS2made no difference on my Lenovo yoga 13.
    Remember to restart your machine.
    2014-10-01T14:16:29+00:00
    http://www.intowindows.com/how-to-enable-two-finger-tap-for-right-click-in-windows/
     the link that you provided is working for one time when i sign out  or restart my pc the problem of 2 finger right click arises again . i followed instructions given on above link but worked for only one time . problem continues .        my pc is hp pavilion 15 notebook pc .  i up graded from windows 8 to windows 8.1 .all functions and programs are working correctly but 2 finger right click is not working for me .
                     i got habituated to 2 finger right click i am finding trobled without it , if there are any solution for above problem , please mail me ******@gmail.com
    2014-11-15T10:59:35+00:00
