32-bit application fails to start after 8.1 upgrade, gives error 0xC000007B because of missing system DLLs.
2013-10-23T07:28:03+00:00
I had been using "IBM Rational ClearQuest Client 7.1.2 for Windows" 32-bit application with Windows 8 Pro x64 without problems.
But after 8.1 upgrade the ClearQuest fails to start and gives error 0xC000007B, which indicates that there's a bad or missing DLL.
I used the Windows 8.1 ISO file from MSDN to do the upgrade and I've also installed the GA updates, but the problem remains the same.
The DependencyWalker reports that the clearquest.exe is missing six Windows 8.1 system DLLs:
API-MS-WIN-CORE-KERNEL32-PRIVATE-L1-1-1.DLL
API-MS-WIN-CORE-PRIVATEPROFILE-L1-1-1.DLL
API-MS-WIN-SERVICE-PRIVATE-L1-1-1.DLL
API-MS-WIN-CORE-SHUTDOWN-L1-1-1.DLL
EXT-MS-WIN-NTUSER-UICONTEXT-EXT-L1-1-0.DLL
IESHIMS.DLL
First three of those files are located in SysWOW64\downlevel, but the 32-bit clearquest.exe is not able to find those DLLs. IESHIMS.DLL is located under WinSxS directory tree, but not available for 32-bit clearquest.exe
But API-MS-WIN-CORE-SHUTDOWN-L1-1-1.DLL and EXT-MS-WIN-NTUSER-UICONTEXT-EXT-L1-1-0.DLL can not be found at all from Windows 8.1 system!
This is very strange because SETUPAPI.DLL (in System32 and SysWOW64) depends on API-MS-WIN-CORE-SHUTDOWN-L1-1-1.DLL (checked with "dumpbin /imports" command)!
And D3D11.DLL depends on the missing EXT-MS-WIN-NTUSER-UICONTEXT-EXT-L1-1-0.DLL.
I've tried to install ClearQuest again but it didn't help. I've also used "sfc /verifyonly" command, but it reports that everyhing is OK.
I've checked two other Windows 8.1 systems that have also been upgraded from Windows 8 and those files are missing also in those systems.
Is it really so that there are system files missing from Windows 8.1 upgrades?
Jari
2014-08-01T19:26:39+00:00
Hi everybody, just found something really interesting.
I've just got an quite old game and tried to play it on my win8.1update, then received 0xc000007b :-(
DependencyWalker told me the missing of six dlls and I just can't find some of those on web QAQ
So I tried to play it on another laptop with XP and I was informed that there is something wrong with xinput1_3.dll
After downloading that dll (for 32-bit system) from the internet, the game works properly in XP :-)
And surprisingly, when I turn back to win8.1, replacing the original xinput1_3.dll of win8.1update with the downloaded one, the game miraculously starts to run!!!
I don't know why it works, but it does work.
For your reference.
Good Luck,
Lichen
2014-11-11T20:05:19+00:00
Hello!
I had problems with this API dll's missing with several 64 bit aplications
such as Magix video professional editor 2015 and Magix Samplitude 2015 along with
some programs from Native.
The solution for me was;
 Visual C++ Redistributable Packages for Visual Studio 2013
Download link:
http://www.microsoft.com/en-us/download/details.aspx?id=40784
I reinstalled (repaired) these 2 files and all programs worked
vcredist_x64.exe
vcredist_x86-exe
Hopefully You experience the same!
44 additional answers
    2014-01-14T18:17:07+00:00
    No that's not the case.
    Actually by doing the update the problem appears LOL!!!
    Our software compiled on VS2012 runs fine on Windows 8.
    BUT, the same software fails on Windows 8.1
    So the update has screwed up something which MSFT refuses to acknowledge.
    2014-01-15T03:41:31+00:00
    I am sorry if I was not clear. I know that the migration of Windows 8 to Windows 8.1 it was what caused the problem. What I am talking about it is the online update of the Windows 8.1 itself that corrected the problem for me. To do that you can do the following steps:
    • On Windows 8.1 that you have the problem go to Control Panel (Right click on the start icon on the desktop >> Control Panel)
    • Search for "Check for updates" and execute it.
    Result: New online updates will be found.
    • Install all updates.
    I hope this solves your problem as did with mine.
    2014-01-15T22:17:55+00:00
    Thank you Rogerio for the response.
    I did update the 8.1 machine with the latest 8.1 updates but that did not solve our problem.
    I am sending the error report to MSFT every time it fails so maybe they will fix it in the next update.
    Incidentally, our problem has to do with one particular API
    RegisterActiveObject
    which does not work in 8.1 or at least not the way we have been using it.
    Maybe someone form MSFT can point me in the right direction on how to resolve this issue with a live support/technical person at MSFT. We are willing to pay for this support at this point but don't know how to go about it!
