I hadn't noticed that before, and after checking again, I only see that message show up for a few seconds every so often. Sometimes it says CPU 3 is parked also.
As for battery control, etc... There's the default Lenovo Power Management, which also allows you to set power modes, but they directly correspond to the Windows power modes. I had Razer Game Booster for a while, but after I realized it wasn't helping, I
uninstalled it. I have AMD Gaming Evolved, which is similar to Steam only it lets you set graphics specifications for your games before launching them.
After encountering the problems, I installed MSI Afterburner, but it can't set a higher CPU speed than 0.78 GHz. I also got AMD Overdrive to try to solve the problems, but it says that my processor doesn't support it (which is what I was told by the second
Lenovo tech that I spoke to).
I'll look into those programs; thanks again for your help :)
Owen
