EDIT: The problem seems to have been fully resolved by doing a clean install of Windows 10.
I use an AMD A6 processor on my Lenovo IdeaPad Flex 15D. Recently, my PC has been slow, and checking the Task Manager shows that the processor speed is only 0.76-0.78 GHz, while my processor's maximum speed is 2.00 GHz. The Resource Monitor says that my
maximum frequency is 38-39% (0.76-0.78 GHz). This happens even when I'm in High Performance mode, and I've checked to make sure that the minimum and maximum speeds (in the power options) are set to 100%. I've also set the ATI Powerplay settings to Maximize
Performance. The speed does not increase even when I'm running many programs at once.
Any help would be very appreciated.
I've noticed something interesting... The CPU speed in the Task Manager always seems to hang around 0.7-0.78 GHz, even when I'm not doing anything else on my laptop. Perhaps there's something that is not only preventing it from going above 0.78 GHz, but
preventing it from going below 0.7 GHz. I have no idea why this is happening.
