Partitioning Surface Pro 3
2014-07-29T02:50:38+00:00
I have a new Surface Pro 3 with Win 8.1 and a 128 GB SSD - love it.  But it's all C:, and I really want to partition it as C, D, E and F drives. However, Paragon's Partition Manager 14, which installed without difficulty, won't let that happen. No matter how I try it will not reduce the size of C:\ to make room for the three other partitions.
Is this a Win 8.1 restriction, or a specific Surface Pro 3 limitation? Or is it inherently not possible to partition an SSD (which I find hard to believe)?  Can someone identify a way to do the partitioning I desire without obliterating the Win 8.1 installation that came on the machine?
2014-08-02T01:15:43+00:00
Hi Rabnud,
Disk Management is a built-in tool in Windows which enables the users to view and manage the installed drive in their computer and the partitions related with those drives. With the help of Disk Management, you can create partition, format partition, extend partition, shrink partition, delete partition, change drive letter. It nearly satisfies all the demands of the users and is convenient for the users, so it is widely used by the users.
Steps to Partition a hard drive with Windows 8/8.1 Disk Management tool:
  1. Open Windows 8 or 8.1 Disk Management by pressing "Windows + R" and typing "diskmgmt.msc". In the pop-up window, right click on C drive and select "Shrink Volume".
  2. In the pop-up window, enter the amount of space to shrink.
  3. Click "Shrink" and we can preview an unallocated space behind C drive. Then, right click on it and select "New Simple Volume". Follow the on screen directions to complete the process.
Thank you.
2014-11-04T15:30:54+00:00
Your comment was the solution to a week long intensive "bug hunt" thank you so much!
  1. I downloaded PerfectDisk Professional Trial
  2. hit the down-arrow below the start button
  3. selected "prepare for shrinking"
  4. Happiness!
I just made an account to express my gratitude.
Thank you!
2015-01-02T06:04:34+00:00
Hi Bohao,
Sorry for the delay in reply.
Your Windows question related to 4K Alignment is more complex than what is typically answered in the Microsoft Answers forums. It is better suited in the TechNet forums. Please post your question in the TechNet forums.
The IT professionals from the TechNet Forums could help you better in this situation.
http://social.technet.microsoft.com/Forums/windows/en-US/home?category=w8itpro
Thank you.
57 additional answers
    2015-10-20T11:40:59+00:00
    I have a just purchased Surface Pro 3 and none of these suggestions really helped.
    I have a 256GB drive and Disk Management only let me shrink it to about 170GB. I wanted about 80GB for my C: drive so I could add a decent sized D: drive.
    Through some research I found the stumbling block to be Bitlocker, but most of the solutions I found to disable it told me to do it from boot. That didn't work or just caused more problems.
    The way I found was to disable it from within Windows.
    Open Control Panel and search for Bitlocker.
    Click on the result and you'll get a windows showing you the available drives.
    Next to each drive will be a menu. I clicked on "Turn of Bitlocker" for each drive and waited for it to complete (there's no progress indicator, it just says "decrypting".
    Once it was complete, I could run the standartd edition of Acronis Disk Director (which wouldn't work before) and it had no problems resizing my drives.
    I hope this helps some of you.
    BTW You can turn Bitlocker back on afterwards.
    Thanks to Eightforums.com. This post gave me the starting point and pictures - http://www.eightforums.com/tutorials/21522-bitlocker-password-change-reset-windows-8-a.html
    2016-08-17T15:53:24+00:00
    Great find!!! This did the trick for me.... Best wishes!
