Partitioning Surface Pro 3
2014-07-29T02:50:38+00:00
I have a new Surface Pro 3 with Win 8.1 and a 128 GB SSD - love it.  But it's all C:, and I really want to partition it as C, D, E and F drives. However, Paragon's Partition Manager 14, which installed without difficulty, won't let that happen. No matter how I try it will not reduce the size of C:\ to make room for the three other partitions.
Is this a Win 8.1 restriction, or a specific Surface Pro 3 limitation? Or is it inherently not possible to partition an SSD (which I find hard to believe)?  Can someone identify a way to do the partitioning I desire without obliterating the Win 8.1 installation that came on the machine?
2014-08-02T01:15:43+00:00
Hi Rabnud,
Disk Management is a built-in tool in Windows which enables the users to view and manage the installed drive in their computer and the partitions related with those drives. With the help of Disk Management, you can create partition, format partition, extend partition, shrink partition, delete partition, change drive letter. It nearly satisfies all the demands of the users and is convenient for the users, so it is widely used by the users.
Steps to Partition a hard drive with Windows 8/8.1 Disk Management tool:
  1. Open Windows 8 or 8.1 Disk Management by pressing "Windows + R" and typing "diskmgmt.msc". In the pop-up window, right click on C drive and select "Shrink Volume".
  2. In the pop-up window, enter the amount of space to shrink.
  3. Click "Shrink" and we can preview an unallocated space behind C drive. Then, right click on it and select "New Simple Volume". Follow the on screen directions to complete the process.
Thank you.
2014-11-04T15:30:54+00:00
Your comment was the solution to a week long intensive "bug hunt" thank you so much!
  1. I downloaded PerfectDisk Professional Trial
  2. hit the down-arrow below the start button
  3. selected "prepare for shrinking"
  4. Happiness!
I just made an account to express my gratitude.
Thank you!
2015-01-02T06:04:34+00:00
Hi Bohao,
Sorry for the delay in reply.
Your Windows question related to 4K Alignment is more complex than what is typically answered in the Microsoft Answers forums. It is better suited in the TechNet forums. Please post your question in the TechNet forums.
The IT professionals from the TechNet Forums could help you better in this situation.
http://social.technet.microsoft.com/Forums/windows/en-US/home?category=w8itpro
Thank you.
57 additional answers
    2014-09-24T16:15:16+00:00
    Dennis,
    I am not sure if the existence of the second Recovery Partition is causing the "Virtual Disk Service Error".  If Shrink Querymax reported Max Reclaimable Bites = 240 GB (245846 MB), you should have been able to shrink the partition.
    In any event, even if you could reduce Volume 0 to meet your requirements, you can not have more than 4 Primary Partitions on a single physical drive.  Four Partitions is the limit.
    I created a bootable USB backup of the Recovery Partition in Volume 3.  The Surface Pro website has the instructions.
    At the end of the process I elected to remove the Recovery Partition from the disk, thereby freeing up a Primary Partition for my own use.  The on board Surface Pro 3 routine also automatically extended my Volume 0 boot partition.
    PerfectDisk will have its limitations.  You will not be able to execute a Boot Time Defrag to move system files.  However, consolidating free space may help.  You can also identify the files that are obstructing your Shrink process.
    RMM
    2014-09-26T12:59:53+00:00
    Hi All,
    In my case Surface3Pro has 256Gb SSD.
    Shrink shows only 1Gb free available space.
    It is new machine with activated MS Office.
    I would like to get explanation what should be done to successfully defragment and create portions before returning it back to best buy.
    Thanks a lot,
    Evgeny
