How to fix Event Viewer ID 2002, 1017 & 3007?
2014-06-30T16:08:31+00:00
ID 2002
IIS-W3SVC-PerfCounters
Setting up Web Service counters failed, please make sure your Web Service counters are registered correctly.
ID 1017
Perflib
Disabled performance counter data collection from the "ASP.NET_64_2.0.50727" service because the performance counter library for that service has generated one or more errors. The errors that forced this action have been written to the application event log. Correct the errors before enabling the performance counters for this service.
ID 3007
Search
Performance monitoring cannot be initialised for the gatherer service, because the counters are not loaded or the shared memory object cannot be opened. This only affects availability of the perfmon counters. Restart the computer.
Thanks!
    2014-08-04T16:36:36+00:00
    Hi Gil,
    Antivirus and anti-malware are same. Viruses are a specific type of malware (designed to replicate and spread), while malware is a broad term used to describe all sorts of unwanted or malicious code. Malware can include viruses, spyware, adware, nagware, trojans, worms, and more.
    2014-08-07T13:26:32+00:00
    ok but I'm still pretty sure they have nothing to do with the event viewer error messages I got
    2014-08-08T06:46:48+00:00
    The Event Viewer is designed to help system administrators keep tabs on their computers and troubleshoot problems. If there isn’t a problem with your computer, the errors in here are unlikely to be important.
    You can generally ignore all of the errors and warnings that appear in the Event Viewer – assuming your computer is working properly.
    Here's is the links to what you need to know about Event 2002, 1017 and****3007 and how to fix it.
    Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs.
    Note: This links doesn't apply for Windows 8.1 but holds good for troubleshooting the issue.
    Event ID 3007 — Search Indexer Performance Counter Availability
    http://technet.microsoft.com/en-us/library/dd364637%28WS.10%29.aspx
    Event ID 2002 — Performance Library Availability
    http://technet.microsoft.com/en-us/library/cc775094%28v=ws.10%29.aspx
    Event ID 1017 — Performance Library Availability
    http://technet.microsoft.com/en-us/library/cc727184%28v=ws.10%29.aspx
    Hope this information helps.
