How to fix Event Viewer ID 2002, 1017 & 3007?
2014-06-30T16:08:31+00:00
ID 2002
IIS-W3SVC-PerfCounters
Setting up Web Service counters failed, please make sure your Web Service counters are registered correctly.
ID 1017
Perflib
Disabled performance counter data collection from the "ASP.NET_64_2.0.50727" service because the performance counter library for that service has generated one or more errors. The errors that forced this action have been written to the application event log. Correct the errors before enabling the performance counters for this service.
ID 3007
Search
Performance monitoring cannot be initialised for the gatherer service, because the counters are not loaded or the shared memory object cannot be opened. This only affects availability of the perfmon counters. Restart the computer.
Thanks!
    2014-07-05T11:02:48+00:00
    Running the Scanhealth returned:
    No component store corruption detected.
    Ok so currently I have these following recurring issues in event viewer:
    1. Setting up Web Service counters failed, please make sure your Web Service counters are registered correctly.
    EventID 2002
    Source: IIS-W3SVC=PerfCounters
    I wasn't able to register this counter. I'm getting "Unable to find initialization file w3svc.ini" 2. Windows cannot load the extensible counter DLL rdyboost. The first four bytes (DWORD) of the Data section contains the Windows error code.
    EventID: 1023
    Source: Perflib 3. The Open Procedure for service "BITS" in DLL "C:\Windows\System32\bitsperf.dll" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
    EventID: 1008
    Source: Perflib 4. Performance monitoring cannot be initialised for the gatherer service, because the counters are not loaded or the shared memory object cannot be opened. This only affects availability of the perfmon counters. Restart the computer.
    eventID: 3006
    Source: Search
    See Event LOG here:
    http://1drv.ms/1mi4i1v
    2014-07-06T06:36:53+00:00
    Hi Gil,
    Thank you for the updates.
    This issue may occur due to any missing driver or updates for the game or due to third party software conflicts.
    Let’s try the following steps and check if it helps:
    Method 1:
    I suggest you to try running the Windows Updates and install all the available updates including the optional driver and firmware updates.
    Windows Update: Frequently Asked Questions
    You may also refer to the Computer manufacturer website and try installing the latest version of chipset and all other device drivers and check if it helps.
    Method 2:
    You may also perform a clean boot and check for the issue.
    A clean boot helps to verify if any third party application services or startup item is causing this issue.
    How to perform a clean boot in Windows
    **Note:**After you have finished the troubleshooting, refer to the section “How to reset the computer to start as usual after troubleshooting with clean boot” to boot the system in normal start up.
    Hope the information helps. Let us know if you need further assistance with Windows related issues. We will be happy to help.
    2014-07-06T12:28:04+00:00
    I don't have updates to install.
    Clean boot won't matter because the messages still show after I've cleared the event viewer log.
    I also set a new user account to no avail.
    2014-07-14T05:53:49+00:00
    Still need help please
    2014-07-14T14:52:44+00:00
    I would request you to perform Clean Boot as suggested by Praseetha. You may get the errors in event manager if any third party programs conflict with Windows system files. A clean boot helps eliminate software conflicts.
    Disclaimer: After you have finished troubleshooting with Clean Boot, follow these steps from section “How to reset the computer to start as usual after clean boot troubleshooting” to reset the computer to start as usual.
    Hope it helps.
