How to fix Event Viewer ID 2002, 1017 & 3007?
2014-06-30T16:08:31+00:00
ID 2002
IIS-W3SVC-PerfCounters
Setting up Web Service counters failed, please make sure your Web Service counters are registered correctly.
ID 1017
Perflib
Disabled performance counter data collection from the "ASP.NET_64_2.0.50727" service because the performance counter library for that service has generated one or more errors. The errors that forced this action have been written to the application event log. Correct the errors before enabling the performance counters for this service.
ID 3007
Search
Performance monitoring cannot be initialised for the gatherer service, because the counters are not loaded or the shared memory object cannot be opened. This only affects availability of the perfmon counters. Restart the computer.
Thanks!
    2014-07-01T06:23:32+00:00
    Hi Gil,
    1. What is the exact issue you are facing with Windows 8.1?
    2. Is your system connected to a domain?
    Event Viewer is a tool that displays detailed information about significant events (for example, programs that don't start as expected or updates that are downloaded automatically) on your computer. Event Viewer can be helpful when troubleshooting problems and errors with Windows and other programs.
    These Events may occur:
    Event ID 2002: If W3SVC is not available, HTTP performance counter data cannot be gathered.
    Event ID 1017: This error might be caused by one of the following conditions:
    • A non-Microsoft DLL caused the error.
    • The list of counters is corrupt.
    • The Remote Registry service is not running on a remote system.
    • The File and Printer Sharing firewall exception is not enabled on a remote system running Windows Vista.
    • The application is running as a user with insufficient privileges.
    Event ID 3007: This may occur due to any corrupted Windows Search settings.
    Let’s refer to the articles and see if the steps provided help you to fix the issue:
    Event ID 2002 — IIS W3SVC Performance Counter Availability
    Event ID 1017 — Performance Library Availability
    Event ID 3007 — Search Indexer Performance Counter Availability
    Hope the information helps. Let us know if you need further assistance with Windows related issues. We will be happy to help.
    2014-07-02T14:23:23+00:00
    1. Nothing is particular, just seeing many errors in Event Viewer
    2. I'm running the default Workgroup domain, it's my home network. Not office or organization.
    I have gone through all the steps in all the articles but they didn't solve the issues.
    And as time goes by, the errors pile up.
    Here is a new one:
    Event ID 1000
    - <Event xmlns="**http://schemas.microsoft.com/win/2004/08/events/event**">
    - <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2014-07-02T13:33:31.000000000Z" />
    <EventRecordID>122604</EventRecordID>
    <Channel>Application</Channel>
    <Computer>GIL-PC</Computer>
    <Security />
    </System>
    - <EventData>
    <Data>BackgroundTaskHost.exe</Data>
    <Data>6.3.9600.16384</Data>
    <Data>5215e1f6</Data>
    <Data>unknown</Data>
    <Data>0.0.0.0</Data>
    <Data>00000000</Data>
    <Data>c0000005</Data>
    <Data>0000000000000000</Data>
    <Data>1678</Data>
    <Data>01cf95fa371b1755</Data>
    <Data>C:\WINDOWS\System32\BackgroundTaskHost.exe</Data>
    <Data>74d8cd9a-01ed-11e4-bf05-0008cae5ef0e</Data>
    <Data>Microsoft.BingWeather_3.0.2.243_x64__8wekyb3d8bbwe</Data>
    <Data>App</Data>
    </EventData>
    </Event>
    Event ID 1026:
    - <System>
    <Provider Name=".NET Runtime" />
    <EventID Qualifiers="0">1026</EventID>
    <Level>2</Level>
    <Task>0</Task>
    <TimeCreated SystemTime="2014-07-02T09:25:50.000000000Z" />
    <EventRecordID>122569</EventRecordID>
    <Security />
    </System>
    - <EventData>
    <Data>Application: SearchFilterHost.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.AccessViolationException Stack: at IcarosPropertyHandler.IPropertyStoreCache.SetValueAndState(IcarosPropertyHandler.PropertyKey ByRef, IcarosPropertyHandler.PropVariant, IcarosPropertyHandler.PropertyStoreCacheState) at IcarosPropertyHandler.IPropertyStoreCache.SetValueAndState(IcarosPropertyHandler.PropertyKey ByRef, IcarosPropertyHandler.PropVariant, IcarosPropertyHandler.PropertyStoreCacheState) at IcarosPropertyHandler.PropertyHandler.LoadProperty(IcarosPropertyHandler.PropertyMap) at IcarosPropertyHandler.PropertyHandler.LoadProperties() at IcarosPropertyHandler.PropertyHandler.IcarosPropertyHandler.IInitializeWithStream.Initialize(System.Runtime.InteropServices.ComTypes.IStream, IcarosPropertyHandler.AccessModes)</Data>
    </EventData>
    </Event>
    2014-07-03T07:09:24+00:00
    Hi Gil,
    Thank you for the updates.
    If you are not connected to any Work domain or not using any IIS (Windows Server), then you may try to perform a SFC scan on the computer which would scan for corrupt system files on the computer and replace them.
    Use the System File Checker tool to repair missing or corrupted system files
    2014-07-03T10:37:42+00:00
    SFC /SCANNOW didn't come up with anything...
    Any other solutions please?
    2014-07-04T05:23:02+00:00
    Hi Gil,
    Since the issue persists, let us try the following steps and check if it helps:
    Method 1:
    You may run the following DISM command from an elevated command prompt and see if the patch will install after you run the DISM command.
    a. Swipe in from the right edge of the screen, and then clickSearch.
    b. Enter command prompt in the Search box.
    c. In the list of results, swipe down on or right-click Command prompt, and then tap or clickRun as administrator.
    In the Administrator Command Prompt window, type the following commands. Press the Enter key after each command:
    DISM.exe /Online /Cleanup-image /Scanhealth DISM.exe /Online /Cleanup-image /Restorehealth
    Method 2:
    If the system was working fine prior to the issue started, you may try performing a System restore and check for the issue.
    a. Press Windows and R key to open run box.
    b. Type rstrui and hit Enter.
    c. Perform System restore to a restore point before yesterday and check if it helps.
    Note: When you perform System Restore to restore the computer to previous state, programs and updates you installed are removed.
