USB port malfunctioning, always says "USB Device not recognized"
2014-07-15T05:39:18+00:00
I have a samsung laptop, model number NP350E7C-A01US. Every time I insert anything into one of my four USB ports, I get the error: "USB Device not recognized".
You can see the laptop here: https://www.samsung.com/us/support/owners/product/NP350E7C-A01US
    2014-07-16T19:50:36+00:00
    Haha yeah, the issues I've been having with this computer have almost been as bad as when I got my Droid Bionic in 2011 :P
    Do you know what Teamviewer is? That is what I usually use. I trust you haha. How do you get offical MSFT support anyways?
    And yeah, I checked the power, it said it was self-powered, for both USB Root Hubs.
    2014-07-16T19:56:33+00:00
    Well, it detected that my brightness was too high and lowered it LOL.
    Here are the details of the sptd error:
    Log Name:      System
    Source:        sptd
    Date:          7/16/2014 1:54:07 PM
    Event ID:      4
    Task Category: None
    Level:         Error
    Keywords:      Classic
    User:          N/A
    Computer:      ChristophersPC
    Description:
    Driver detected an internal error in its data structures for .
    Event Xml:
    <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
      <System>
        <Provider Name="sptd" />
        <EventID Qualifiers="49156">4</EventID>
        <Level>2</Level>
        <Task>0</Task>
        <Keywords>0x80000000000000</Keywords>
        <TimeCreated SystemTime="2014-07-16T17:54:07.983131200Z" />
        <EventRecordID>39231</EventRecordID>
        <Channel>System</Channel>
        <Computer>ChristophersPC</Computer>
        <Security />
      </System>
      <EventData>
        <Data>
        </Data>
        <Binary>000000000100000000000000040004C0FD0000000000000000000000000000000000000000000000</Binary>
      </EventData>
    </Event>
    Maybe I should just go hunting for these errors and post them all here, I have a lot of them in my event log, I'm not sure if that is normal.
    Here is another error:
    Log Name:      System
    Source:        Microsoft-Windows-DistributedCOM
    Date:          7/16/2014 1:12:13 AM
    Event ID:      10016
    Task Category: None
    Level:         Error
    Keywords:      Classic
    User:          ChristophersPC\Christopher
    Description:
    The application-specific permission settings do not grant Local Launch permission for the COM Server application with CLSID
    {7022A3B3-D004-4F52-AF11-E9E987FEE25F}
     and APPID
    {ADA41B3C-C6FD-4A08-8CC1-D6EFDE67BE7D}
     to the user ChristophersPC\Christopher SID (S-1-5-21-2541327983-389364735-1342229692-1001) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
    Event Xml:
      <System>
        <Provider Name="Microsoft-Windows-DistributedCOM" Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" />
        <EventID Qualifiers="0">10016</EventID>
        <Version>0</Version>
        <Level>2</Level>
        <Task>0</Task>
        <Opcode>0</Opcode>
        <Keywords>0x8080000000000000</Keywords>
        <TimeCreated SystemTime="2014-07-16T05:12:13.613459900Z" />
        <EventRecordID>39143</EventRecordID>
        <Correlation />
        <Execution ProcessID="880" ThreadID="932" />
        <Security UserID="S-1-5-21-2541327983-389364735-1342229692-1001" />
      </System>
      <EventData>
        <Data Name="param1">application-specific</Data>
        <Data Name="param2">Local</Data>
        <Data Name="param3">Launch</Data>
        <Data Name="param4">{7022A3B3-D004-4F52-AF11-E9E987FEE25F}</Data>
        <Data Name="param5">{ADA41B3C-C6FD-4A08-8CC1-D6EFDE67BE7D}</Data>
        <Data Name="param6">ChristophersPC</Data>
        <Data Name="param7">Christopher</Data>
        <Data Name="param8">S-1-5-21-2541327983-389364735-1342229692-1001</Data>
        <Data Name="param9">LocalHost (Using LRPC)</Data>
        <Data Name="param10">Unavailable</Data>
        <Data Name="param11">Unavailable</Data>
      </EventData>
    </Event>
    2014-07-16T20:04:57+00:00
    Here are some more:
    Log Name:      System
    Source:        Service Control Manager
    Date:          7/16/2014 1:11:06 AM
    Event ID:      7000
    Task Category: None
    Level:         Error
    Keywords:      Classic
    User:          N/A
    Description:
    The KmxCF service failed to start due to the following error:
    The system cannot find the file specified.
    Event Xml:
      <System>
        <Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
        <EventID Qualifiers="49152">7000</EventID>
        <Level>2</Level>
        <Task>0</Task>
        <Opcode>0</Opcode>
        <TimeCreated SystemTime="2014-07-16T05:11:06.221764900Z" />
        <EventRecordID>39132</EventRecordID>
        <Correlation />
        <Execution ProcessID="760" ThreadID="764" />
        <Security />
      </System>
      <EventData>
        <Data Name="param1">KmxCF</Data>
        <Data Name="param2">%%2</Data>
        <Binary>4B006D007800430046000000</Binary>
      </EventData>
    </Event>
    I get this one a lot:
    Log Name:      System
    Source:        Microsoft-Windows-Kernel-PnP
    Date:          7/16/2014 1:10:39 AM
    Event ID:      219
    Task Category: (212)
    Level:         Warning
    Keywords:
    User:          SYSTEM
    Description:
    The driver \Driver\BTATH_BUS failed to load for the device ROOT\SYSTEM\0004.
    Event Xml:
      <System>
        <Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9C205A39-1250-487D-ABD7-E831C6290539}" />
        <EventID>219</EventID>
        <Level>3</Level>
        <Task>212</Task>
        <Opcode>0</Opcode>
        <Keywords>0x8000000000000000</Keywords>
        <TimeCreated SystemTime="2014-07-16T05:10:39.474891900Z" />
        <EventRecordID>39123</EventRecordID>
        <Correlation />
        <Execution ProcessID="4" ThreadID="228" />
        <Security UserID="S-1-5-18" />
      </System>
      <EventData>
        <Data Name="DriverNameLength">16</Data>
        <Data Name="DriverName">ROOT\SYSTEM\0004</Data>
        <Data Name="Status">3221226092</Data>
        <Data Name="FailureNameLength">17</Data>
        <Data Name="FailureName">\Driver\BTATH_BUS</Data>
        <Data Name="Version">0</Data>
      </EventData>
    </Event>
    There is a ton of errors in there from Service Control Manager.
    2014-07-16T20:13:50+00:00
    One thing that I thought I would tell you is that I can't recall a time when that USB port worked. I literally can't recall a time. It has been like this for many months.\
    I'm not even sure what alcohol 120 is. After doing a search on my computer for it, 1 file came up titled "element_main". Should I uninstall Daemon Tools Pro?
    2014-07-16T20:27:51+00:00
    Btw I don't see the option to view all instances of the error.
