BUG: CHKDSK stuck at 11% for hours, but was actually working
2013-10-29T15:12:28+00:00
I ran CHKDSK on my Windows 8.1 Pro 64bit laptop.  The message said that it was up to 11% and then it stopped advancing for ages.  I thought that CHKDSK had stalled or crashed, but it turns out that it was working, it's just that it took several hours to complete one stage but it didn't update the progress indicator.
MORE DETAILS
I ran CHKDISK from the command prompt on my C drive and it offered to run the command on the next restart.  I answered yes and restarted, and CHKDSK ran, updating its progress, but it stopped at 11% and stayed there for ages and ages.
Note that in Windows 8.1, CHKDSK doesn't display lines of text as it goes along like in certain earlier versions of Windows.  It just displays a single line, e.g. "Scanning and repairing drive (C:): 11% complete" that gets updated from time to time.
At first I thought it was stalled or crashed, so I rebooted the laptop.  CHKDSK ran again and once again got stuck at 11%.  So I rebooted the laptop with a recovery USB and ran CHKDISK from the command prompt.  This one displayed more progress information.  It estimated that a particular stage would take 3 or 4 hours (it fluctuated from one to the other at first before settling on over 3 hours and then slowly counting down).  After several hours it completed successfully, fixing some errors and reporting its results.
I rebooted the computer again, from the hard drive.  CHKDSK ran again (since it didn't complete before) and after several hours it completed.  It warned me that Windows didn't close normally (because I interrupted the previous CHKDSK) and gave me some options.
So it looks like there's one stage in CHKDSK where the status line isn't getting updated regularly.  Could Microsoft please fix this?
EDIT: corrected spelling of subject heading.
    2015-02-24T17:11:15+00:00
    I'm stuck @ 12%, n already 3hrs now. Dell N5420, 6GB ram 1 GB VRam, windows 8.1 for now, was 7 home basic (suddenly error n blocked, black screen, said I was using non original.
    W/ this win 8,  sometimes I got: camera not connected error message, nvdia control panel simetimes error message too.
    1st time blue screen w/ win 8.1, I wasn't able to play game i'm usually playing, a note that my comp display memory only set @ 30Mb, 256 is minimum. When I check, again... error again w/ nvidia control panel (said: no nvidia detected)
     What should I do?
    2015-05-22T13:19:36+00:00
    When Windows 8.1 starts loading (Windows logo with loading circle below), start pressing any key or esc, It is crazy that microsoft left 1 sec to skip chkdsk. This will skip checkdisk
    2015-05-26T11:16:26+00:00
    Hey ! I've been having the same problem. My scanning stuck at 13 % for hours.
    i reboot my Laptop and the scanning starts again. But i noticed one thing right before the scanning starts and it says "Press any key to stop your scanning". so i pressed and it stopped and my laptop is working fine now.
    I did this CHKDSK/f/r  because of my disk always stick to 100%.
    for this issue there is another solution just open your CMD.EXE as an admin and write this command
    net.exe stop "Windows search"
    and now my disk issue is fine so far.
    i hope it'll work for you guys
    cheers Ahsan
    2015-07-04T22:30:20+00:00
    2015-07-14T08:22:49+00:00
    just clicked escape when it is starting it stopped
    this worked for me!!!
