BUG: CHKDSK stuck at 11% for hours, but was actually working
2013-10-29T15:12:28+00:00
I ran CHKDSK on my Windows 8.1 Pro 64bit laptop.  The message said that it was up to 11% and then it stopped advancing for ages.  I thought that CHKDSK had stalled or crashed, but it turns out that it was working, it's just that it took several hours to complete one stage but it didn't update the progress indicator.
MORE DETAILS
I ran CHKDISK from the command prompt on my C drive and it offered to run the command on the next restart.  I answered yes and restarted, and CHKDSK ran, updating its progress, but it stopped at 11% and stayed there for ages and ages.
Note that in Windows 8.1, CHKDSK doesn't display lines of text as it goes along like in certain earlier versions of Windows.  It just displays a single line, e.g. "Scanning and repairing drive (C:): 11% complete" that gets updated from time to time.
At first I thought it was stalled or crashed, so I rebooted the laptop.  CHKDSK ran again and once again got stuck at 11%.  So I rebooted the laptop with a recovery USB and ran CHKDISK from the command prompt.  This one displayed more progress information.  It estimated that a particular stage would take 3 or 4 hours (it fluctuated from one to the other at first before settling on over 3 hours and then slowly counting down).  After several hours it completed successfully, fixing some errors and reporting its results.
I rebooted the computer again, from the hard drive.  CHKDSK ran again (since it didn't complete before) and after several hours it completed.  It warned me that Windows didn't close normally (because I interrupted the previous CHKDSK) and gave me some options.
So it looks like there's one stage in CHKDSK where the status line isn't getting updated regularly.  Could Microsoft please fix this?
EDIT: corrected spelling of subject heading.
    2017-08-27T06:26:20+00:00
    Glad I found this. Windows 10 and been having it freeze up when in the file explorer. PC is just a year old but something is wrong. The RAM check didn't give me results like it said so ran chkdsk and it got stuck at 11%. I waited it out since finding this but it restarted and gave no results again! Well I ran it /r maybe I'll be lucky and it fixed something.
    2017-09-11T02:47:13+00:00
    If you are using a wireless keyboard it isn't operational until after Window finishes booting.
    2017-10-15T23:50:45+00:00
    in reply to Mike Gyt  9/25.16  Quot " Just to make sure that all issues are found and dealt with, run a check disk scan first, by typing in the command
    chkdsk C: /scan
    and pressing the Enter key. As it scans, it will fix anything that it can without being offline. Once that is finished, type in the command
    chkdsk C: /spotfix
    and press the Enter key. You’ll see the command prompt tell you that it, “…cannot run because the volume is in use by another process.” It will then ask you if you, “Would… like to schedule this volume to be checked the next time the system restarts? (Y/N)” Type Y and press Enter to schedule Check Disk. Now, restart your computer.
    This time Check Disk will run and fix any problems that were identified in the scan. Because it’s only fixing those specific problems, the process only takes a few seconds to a few minutes." Unquote
    IT ALSO  WORKS PERFECTLY IN WINDOWS 10.
    2017-11-27T18:45:42+00:00
    chkdsk C: /scan
    chkdsk C: /spotfix
    This is faster because it isn't doing the same thing. It can only scan part of the drive, as noted, and then it spotfixes what it found.The problem is that it didn't scan a large portion of the drive, so it just completely ignores that portion, errors and all.
  5. Deleted
