SkyDrive Sync Engine Host
2013-10-19T14:50:56+00:00
So far the update to Windows 8.1 has gone very well. I have, however, noticed an issue on ONE of my PCs that's been updated.
The SkyDrive Sync Engine Host process in Task Manager is constantly consuming 12 - 15% of the CPU. Now all of my files that I've chosen to sync have already synced properly. The 'Size' and 'Size on Disk' match for all of the folders I've marked to sync offline.
I've rebooted the PC and, upon restart, the process goes right back in to its CPU consumption.
I will note, that even though the CPU consumption is up, the Network Utilization is not. So it can't be constantly downloading or uploading anything since it's not using the network.
Any ideas as to why this is happening and how I can fix it?
Thanks in advance.
    2014-03-13T21:53:37+00:00
    thnx danielgr, I have tried all of those things and unfortunately the problem comes back intermittently and always after a reboot.
    I think for some the troubleshooter or killing the process is only a temporary solution. Has anybody found another solution yet?
    2014-03-23T14:13:27+00:00
    After hours of searching etc. I found the fix or at least for me.
    Go to your "Task Manager" and close both SkyDrive services.
    Next, go to Windows Explorer and navigate to:
    C:\Users%USER%\AppData\Local\Microsoft\Windows\SkyDrive
    Delete the "SkyDrive" folder after backing up your SkyDrive date elsewhere. (just encase.  This is just a settings folder but any corrupted files will go missing after this.
    Do this t all computers using the same account.  Takes a few minutes or so depending on your account size.  It will start with nothing then quickly fill in with all your files from the cloud.
    Note: %USER% is replaced with your windows login; you will recognize I when you get to the user folder area i.e. C:\Users\
    Hope this helps.  :)
    Thank you good sir! After one year it is now finally working properly!!!
    Thank you!!!
  3. Deleted
    2014-03-24T20:08:12+00:00
    Hope this helps.  :)
    My problem: the SkyDrive App was uploading a few hundred music files, but was stuck on one of them. I had no way that I could cancel the uploading, so I followed the steps in RACoutu's post:
    and then opened the SkyDrive app again. All my files came back, and everything appears to be working wonderfully.
    Thank you, thank you, thank you.
    Note: I am only using SkyDrive with my Asus T100. Also, I did not go to the SkyDrive website at all. Everything was done from the desktop and metro/modern environment.
    2014-04-07T15:00:49+00:00
    Had the same problem.
    Tried to no avail:
    • Restart the PC, kill and restart SkyDrive, etc.
    • RaCoutu solution at the end of page1 on this thread
    Finally got it solved by:
    • Running Microsoft Skydrive Troubleshotter (direct link), and choosing "Reset SkyDrive".
    Hope that may help other people, since it was really easy and quick for a fix.
    The SkyDrive Troubleshooter resolved my issue. Thanks!
    (It is a bit worrisome that a SkyDrive Troubleshooter is required.... I would expect it to work properly or to be resolved through Windows Updates... OneDrive being so tightly integrated with Windows 8.1 and all...)
