Remote desktop connection. An internal error has occurred.
2014-02-25T17:53:26+00:00
The error occurs on a Windows 7 Home computer.
I connect successfully through a Sonic Wall VPN client.
I can ping the IP address of the remote computer.
I run remote desktop (using IP address of the remote computer) and get error:
"Remote desktop connection.  An internal error has occurred."
It used to work flawlessly and all of a sudden quit working.
Please advise.
2016-07-28T19:05:56+00:00
To resolve this issue, I performed the following actions:
Open RDP
Enter the IP address of the remote computer
Click Show Options
Click Experience
Uncheck Reconnect if the connection is dropped
Click Connect
2014-02-27T12:26:19+00:00
Please close the case.
I fixed it.
It was a VPN configuration problem on the Sonic Wall.
48 additional answers
    2016-04-05T00:52:40+00:00
    In my case, the issue was being caused by asymmetric routing. The solution was to turn off one of the two NICs.
  2. Deleted
    2016-04-05T01:56:47+00:00
    Thank you for your response.
    Apart from suggestions provided by PineHut, you may also post your question on TechNet forums to get better assistance from IT professionals.
    TechNet forum
    https://social.technet.microsoft.com/Forums/en-US/home?category=Windows10ITPro
    Thank you
