To resolve this issue, I performed the following actions:
Open RDP
Enter the IP address of the remote computer
Click Show Options
Click Experience
Uncheck Reconnect if the connection is dropped
Click Connect
The error occurs on a Windows 7 Home computer.
I connect successfully through a Sonic Wall VPN client.
I can ping the IP address of the remote computer.
I run remote desktop (using IP address of the remote computer) and get error:
"Remote desktop connection. An internal error has occurred."
It used to work flawlessly and all of a sudden quit working.
Please advise.
Open RDP
Click Show Options
Click Experience
Click Connect
Please close the case.
I fixed it.
It was a VPN configuration problem on the Sonic Wall.
Thanks Todd,
Connecting with the IP worked for me.
I first turned off the Persistent bitmap caching in the remote desktop options and that got rid of the internal error message. Now, the connection kept disconnecting and reconnecting.
I changed the MTU to 1400 from 1500 and now the remote connection is steady.
