How to re-enable Bluetooth in PC Settings
2013-10-17T12:48:38+00:00
I recently turned off my Bluetooth device by
1.       Opening PC Settings
2.       Selecting PC and devices and then Bluetooth.
3.       Changing the Manage Bluetooth devices switch to Off.
Now Bluetooth settings don’t even appear in PC Settings.  If I go to PC Settings, and then PC and devices, the Bluetooth settings have disappeared.
How can I turn my Bluetooth devices back on?
2013-10-17T12:49:16+00:00
This can happen if the Bluetooth device uses a Bluetooth 3.0 radio that is turned off by the manufacturer’s software.
If turning the Bluetooth device off causes your Bluetooth settings to disappear, follow these steps to re-enable your Bluetooth device:
1.     Open PC Settings
2.     Select Network, and then Airplane mode.
If your Bluetooth device was previously paired, there should be an Enable Bluetooth switch.  Switch it to On.
2014-09-09T11:38:24+00:00
Hello Athayde,
Thank you for the reply.
I appreciate your concern.
Did you try using suggestions provided in the previous post?
Please refer to suggestions from Rohit Siddegowda replied on October 26, 2013 and check if it helps.
http://answers.microsoft.com/en-us/windows/forum/windows8_1-hardware/windows-81-bluetooth/8392789d-be26-4594-b394-02a23017d97f
I hope this helps.
Thank you
54 additional answers
    2015-02-04T10:06:18+00:00
    Hi Ratandeep
    Thank you for your continued support.
    HP had instructed me to get drivers for the laptop for Bluetooth from them - which as we know didn't work.
    So i went online, downloaded the drivers for the Manufacturer of the Bluetooth Device (Ralink) installed  and restarted and Hey, I have Bluetooth!!
    Thank you - working with you made me think outside the box  :o)
    Now i have to figure out what else isn't working apart from the Fn key which although isn't important is annoying the hell out me - i don't like it to beat me lol
    Thanks again
    2015-02-04T10:33:02+00:00
    Hello Suzi,
    Thank you for your response.
    I am glad that the Bluetooth is working.
    I appreciate your efforts.
    However, for Fn key issue, please check in BIOS if Fn key combination is disabled. If so, please enable it from BIOS.
    Refer this article:
    http://support.hp.com/us-en/document/c02035108
    Note: Modifying BIOS/ complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
    Please do let us know if you need any further assistance.
    Thank you
    2015-02-04T10:47:27+00:00
    HI -Active keys is definitely enabled in Bios.
    I tried installing the Active Keys driver again.
    There is some Fn Key functionality.
    e.g. The Flight mode can be turned on and off but only after several presses of the relevant key (f12 in this case)
    The same happens with the sound keys.
    So it would appear that there is some compatibility issue with Windows 10 maybe?
