How to re-enable Bluetooth in PC Settings
2013-10-17T12:48:38+00:00
I recently turned off my Bluetooth device by
1.       Opening PC Settings
2.       Selecting PC and devices and then Bluetooth.
3.       Changing the Manage Bluetooth devices switch to Off.
Now Bluetooth settings don’t even appear in PC Settings.  If I go to PC Settings, and then PC and devices, the Bluetooth settings have disappeared.
How can I turn my Bluetooth devices back on?
2013-10-17T12:49:16+00:00
This can happen if the Bluetooth device uses a Bluetooth 3.0 radio that is turned off by the manufacturer’s software.
If turning the Bluetooth device off causes your Bluetooth settings to disappear, follow these steps to re-enable your Bluetooth device:
1.     Open PC Settings
2.     Select Network, and then Airplane mode.
If your Bluetooth device was previously paired, there should be an Enable Bluetooth switch.  Switch it to On.
2014-09-09T11:38:24+00:00
Hello Athayde,
Thank you for the reply.
I appreciate your concern.
Did you try using suggestions provided in the previous post?
Please refer to suggestions from Rohit Siddegowda replied on October 26, 2013 and check if it helps.
http://answers.microsoft.com/en-us/windows/forum/windows8_1-hardware/windows-81-bluetooth/8392789d-be26-4594-b394-02a23017d97f
I hope this helps.
Thank you
54 additional answers
    2014-09-22T09:37:44+00:00
    Hello Jill,
    Thank you for the update.
    I am sorry for late response.
    I appreciate your time and patience.
    I would suggest you to try using steps provided in this article and check if it helps.
    Refer:
    Windows 8 How-to: Mice
    http://www.microsoft.com/hardware/en-us/help/windows-8/how-to/mouse/connecting-bluetooth-device
    I would also suggest you to install IntelliPoint software using suggestions provided in this article and check.
    Refer:
    Install mouse and IntelliPoint software
    http://support.microsoft.com/kb/258785
    Please keep us informed about the status of the issue.
    Thank you
    2014-10-06T14:39:57+00:00
    My bluetooth won't be 'enabled.' It was working one moment and then it disappeared. When I found it again, I was unable to toggle it on. I have a Dell XPS with 8.1. Going crazy here. Spent hours already trying to fix this.
    2014-10-26T14:19:28+00:00
    "b. Right-click on the driver and click on ‘properties’."
    In Device Manager, Bluetooth properties, my driver is up to date. I found it at C:\Windows\System32\drivers\btcusb.sys. I right-clicked & selected Properties but there was no ‘Run this program in compatibility mode for’ checkbox. (There is "Opens with: Unknown application" & the option to change this, but offering a list of common applications.)
    I'm running Win 7, & have NEVER in 4 years got Bluetooth to work on it
