How to re-enable Bluetooth in PC Settings
2013-10-17T12:48:38+00:00
I recently turned off my Bluetooth device by
1.       Opening PC Settings
2.       Selecting PC and devices and then Bluetooth.
3.       Changing the Manage Bluetooth devices switch to Off.
Now Bluetooth settings don’t even appear in PC Settings.  If I go to PC Settings, and then PC and devices, the Bluetooth settings have disappeared.
How can I turn my Bluetooth devices back on?
2013-10-17T12:49:16+00:00
This can happen if the Bluetooth device uses a Bluetooth 3.0 radio that is turned off by the manufacturer’s software.
If turning the Bluetooth device off causes your Bluetooth settings to disappear, follow these steps to re-enable your Bluetooth device:
1.     Open PC Settings
2.     Select Network, and then Airplane mode.
If your Bluetooth device was previously paired, there should be an Enable Bluetooth switch.  Switch it to On.
2014-09-09T11:38:24+00:00
Hello Athayde,
Thank you for the reply.
I appreciate your concern.
Did you try using suggestions provided in the previous post?
Please refer to suggestions from Rohit Siddegowda replied on October 26, 2013 and check if it helps.
http://answers.microsoft.com/en-us/windows/forum/windows8_1-hardware/windows-81-bluetooth/8392789d-be26-4594-b394-02a23017d97f
I hope this helps.
Thank you
54 additional answers
    2015-02-04T10:55:03+00:00
    Hello Suzi,
    Thank you for updating us on the issue.
    It is possible that there is some compatibility issue with Windows 10 technical preview.
    However, you may try performing clean boot to check if the issue with Fn key is causing due to software conflicts.
    Refer:
    How to perform a clean boot in Windows
    http://support2.microsoft.com/kb/929135
    Clean boot is performed to start Windows by using a minimal set of drivers and startup programs. This helps eliminate software conflicts that occur when you install a program or an update or when you run a program.
    Note: After you have finished troubleshooting, follow these steps from section “How to reset the computer to start as usual after clean boot troubleshooting” to reset the computer to start as usual.
    Thank you
    2015-02-14T01:12:53+00:00
    Come on man.... instead of copy paste your answer each time give us a solution !!!
    2015-03-05T05:07:28+00:00
    Thank you Microsoft for your reply, i have enabled my blue-tooth device now.
