Qualcomm Atheros AR9485WB-EG - wireless adapter occasionally loses connection (Windows 8.1)
2013-12-07T13:47:35+00:00
I have an ASUS S451LB laptop.
Running Windows 8.1.
Using Qualcomm Atheros AR9485WB-EG Wireless Network Adapter.
I have an extremely annoying problem lately - I am surfing the web, connected to my home network through WiFi, and every now and then (approximately once an hour or so) my network connection fails. The network notification doesn't show an exclamation mark or anything, everything seems fine but a connection would not be established and I would not be able to use the internet for about 1-3 minutes. Sometimes the problem would fix itself and my connection would renew, and sometimes I rather not wait and when I open the troubleshooting program it resets my WiFi adapter and reconnects to my home network and everything is normal again.
I have two other laptops connected to my home network (Both HP laptops, one is on win7, the other is 8.1) that do not suffer from this odd wireless behavior. Same goes for my android devices, they never fail the connection to my home network. In addition to that I've also connected to my router directly using cable connection for a few days, and never suffered these connection disturbances. Therefore I presume the problem lies within my ASUS laptop's WiFi adapter.
Yesterday I've tried reinstalling the drivers version 10.0.0.263 (currently the latest), also reinstalled the whole Qualcomm bluetooth connection suite as well and problem still persists.
If anyone could shed some light and help me fix this horrible WiFi adapter issues I'd fly over and buy him a beer personally!!
2013-12-08T06:07:27+00:00
Hi Sinvany,
I would suggest you to clean install the drivers by uninstalling the drivers from device manager and reinstalling it and check if it helps:
Download drivers from this Asus link:
http://support.asus.com/download.aspx?SLanguage=en&p=3&s=554&m=ASUS+VivoBook++S451LB&os=&hashedid=latm32feTKbHlUm8
You must be logged on as an administrator to perform these steps.
  1. Open Device Manager by pressing Windows key + X, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.‌ If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. In Device Manager, locate the device you want to update, and then double-click the device name.
  3. Click the Driver tab, and then click Uninstall drivers and follow the instructions.
  4. Restart the computer install the downloaded drivers and check.
Follow the suggestion from this link. These steps can help if you can’t connect to Wi-Fi, you have limited connectivity, your connection signal is weak or drops intermittently, or you can’t find a network.
Can’t connect to a wireless network
http://www.microsoft.com/surface/en-us/support/networking-and-connectivity/cant-connect-to-a-wireless-network
Wired and wireless network problems
http://windows.microsoft.com/en-IN/windows/network-connection-problem-help#network-problems=windows-81&v1h=win81tab1&v2h=win7tab1&v3h=winvistatab1&v4h=winxptab1
Hope this helps. If you need further assistance with Windows, let us know and will be glad to help.
59 additional answers
    2014-02-04T06:19:05+00:00
    I already did this, but I imported added the .278 driver. It is still stable and good download rate, but it drops me anyway from time to time. I can't exactly say when, because I leaved the connection to the wifi connected and gamed a few hours. Once i checked the event viewer, i saw the Event 8002 with the disconnects und the WLAN Autoconfig.
    2014-02-05T09:10:20+00:00
    I have bought a Asus Vivobook S400CA-CA202H with the qualcomm atheros ar9485wb-eg and Windows 8 and i also had very low WiFi speed and numerous disconnects.
    Other devices on my WLAN are working properly.
    After seeking for 2 weeks for a solution i tried just about everything: other drivers, remove antivirus, other firmware/settings (encryption, MTU, enz.)router,
    reinstall OS, firewall settings, IP settings, power saving settings of the adapter. You name it.
    But this was the solution for me!!
    I noticed that the Asus Power4Gear Hybrid has i mind of it's own and constantly adjusted the performance settings.
    I removed Asus Power4Gear Hybrid and set the Windows 8 power scheme to high performance.
    I also configured the schema advanced settings for the wireless connection (maximum performance) and PCI express (disable).
    Good luck!
    Roelof
    You are talking about Windows 8.0 pure and this is a 8.1 AR9485 issues forum.. In 8.0 there are some issues which can be solved by driver updates and so on, but in 8.1 there are some hidden issues.
    2014-02-18T16:16:53+00:00
    This problem is not because of Windows 8 or Windows 8.1. The problem lies within the network adapter itself. I am having the exact same problem on a Windows 7 machine and have done all of the device driver and reinstall methods listed above. I have also tried the power saving settings and still no solution. However, I will say that the problem did not exist until there was some Microsoft updates, so there could be a problem within Microsoft's programming, but it is not because of 8.1 alone as some have made it sound. A fix needs to be found as this same network adapter is used in many devices and causing a great deal of people problems.
    2014-02-18T21:14:31+00:00
    Well.. The current status is that since I uninstalled by the setup the driver, removed the installed driver in the device manager too for the Wifi, rebooted, installed the .279(got it from the Asus Support), but even that this alone didn't helped itself, I also had some updates from MS(they came some days later after I got the driver and around one week from now back) and since installed them, since the 07.02.2014 I haven't drops anymore.. Don't want to paint the devil on the wall, but till now no drops. anymore.. I think for Fyreman907, you could have a hardware fault or just driver fault as the win7 driver for the AR9485 are even there not very know for "stability"...  I think that for most user there is a special mixture of driver fault and OS shits..
