sir i will definitely do this bt after sometime as m having my end sem exams frm 17/5 onwards thn will let u knw d status of computer
thanks
Original Title: explorer.exe file creating problem......
i bought an hp laptop with genuine windows 8.....
earlier it operated nycly bt nw its encountering a problem. when i switch on my lapy the home screens comes in front of me bt without doing anything suddenly desktop opens & a dialog box appear with ! sign in a yellow triangle & written explorer.exe. m facing this problem for more thn a month & my laptop z also slowed down. i have thoroughly scanned my pc with avast internet security & windows defender bt no result came out except 3 viruses which i deleted on the spot.
if any person can help me out in getting rid of this problem i will b very thankful to him/her.
thank you.
thanks
Hi Ashish,
Thank you for keeping us posted. Please reply us with the results once you try the steps suggested in my earlier post. Best of luck for your exams.
sir m having a problem in installing imp windows updates...
plz assist me wat to do in this case
earlier i installed windows updates with ease.....
Hi Ashish,
Could you please let us know which are updates which you are not able to install?
What happens when you try to install the update? Do you receive any error message?
Please refer to the following link:
Troubleshoot problems with installing updates
http://windows.microsoft.com/en-ca/windows/troubleshoot-problems-installing-updates#1TC=windows-8
Please reply us with the required information to assist you further.
sir 1 was security related update
2nd was normal one
attaching screen shots
i tried many times bt it showed "windows ran into a problem"
