Dialog box appears with ! sign in a yellow triangle appears while accessing Windows Explorer
2014-04-16T19:47:00+00:00
Original Title: explorer.exe file creating problem......
i bought an hp laptop with genuine windows 8.....
earlier it operated nycly bt nw its encountering a problem. when i switch on my lapy the home screens comes in front of me bt without doing anything suddenly desktop opens & a dialog box appear with ! sign in a yellow triangle & written explorer.exe. m facing this problem for more thn a month & my laptop z also slowed down. i have thoroughly scanned my pc with avast internet security & windows defender bt no result came out except 3 viruses which i deleted on the spot.
if any person can help me out in getting rid of this problem i will b very thankful to him/her.
thank you.
    2014-04-17T10:28:31+00:00
    Hi Ashish,
    This issue can be caused due to any of the following issues:
    • System files on your PC may be corrupt or mismatched with other files.
    • Some third party applications or services running on your PC may be causing issues with Windows Explorer.
    Please assist me with more information related to this issue.
    1. What is the model of your HP computer?
    2. Do you receive any error message or prompt when you access Windows Explorer?
    Please follow the methods mentioned below.
    Method 1: Run the System Maintenance troubleshooter.
    a. Press Windows key + W and type Troubleshooting.
    b. Select Troubleshooting.
    c. Select view all on the top left corner.
    d. Click System Maintenance, follow onscreen instructions.
    Method 2:
    I would suggest you check the issue in Safe mode. If the issue doesn’t persist in safe mode perform clean boot.  Follow the steps.
    Step 1: Refer the following link to boot the computer in safe mode:
    http://windows.microsoft.com/en-US/windows-8/windows-startup-settings-including-safe-mode
    If the issue does not occur in safe mode you may move to step 2:
    Step 2: Clean boot process will help you determine which third party program/app that is causing this issue. It could be some other application or programs, which runs on the computer at the background, leading to this issue.
    I would suggest you to perform clean boot and check.
    Refer to the link below to perform clean boot:
    How to perform a clean boot in Windows
    http://support.microsoft.com/kb/929135
    Note: Please go through the section: How to reset the computer to start as usual after troubleshooting with clean boot of the Kb article to boot the computer in normal startup after fixing the issue.
    Method 3:
    Let us try to run System File Checker (SFC Scan) as this could be an issue with corruption in Windows system files.
    System File Checker is a utility in Microsoft Windows that allows users to scan for and restore corruptions in Windows system files
    Perform System File Check (SFC), and then check if this fixes the issue.
    Follow the steps:
    1. Press Windows Key + Q to open Charms Bar.
    2. Type “cmd” without quotes in the search box.
    3. On the left pane, right click on the cmd option and select Run as Administrator.
    4. Type ‘sfc /scannow’ without quotes and hit enter.
    Refer: **http://support.microsoft.com/kb/929833/en-us**
    Note: It may ask for windows installation DVD to fix and to enable SFC to make more than minor repairs. Some files saved on your computer might get deleted when fixing corrupted files.
    If the issue persist, please provide us the event viewer logs to find the exact cause and to troubleshoot the issue further.
    NOTE: Try to access Windows Explorer, so that event viewer record the logs.
    Event Viewer is a tool that displays detailed information about significant events (for example, programs that don't start as expected or updates that are downloaded automatically) on your computer. Event Viewer can be helpful when troubleshooting problems and errors with Windows and other programs.
    1. Press the Windows key and X and select Event Viewer.
    2. This will bring up the Event Viewer box. Click to open the event viewer.
    3. In the left pane, expand out Windows Logs.
    4. Most of your event will be Information. You may see Yellow Warnings or Red Errors.
    For more information refer to the following link: **http://windows.microsoft.com/en-in/windows7/what-information-appears-in-event-logs-event-viewer**
    Note: Also applies for Windows 8.
    Also provide us the screen shot of dialog box appear with ! sign in a yellow triangle, so that we get the clear picture of the issue you are facing. Refer to the following link for reference.
    How to include a screenshot in your post
    **http://answers.microsoft.com/en-us/windows/wiki/windows\_other-windows\_programs/how-to-include-a-screenshot-in-your-post/2594b08e-32a3-476a-85a6-b021181be7e4**
    Please reply us on the status of the issue to assist you further.
    2014-04-17T19:45:54+00:00
    sir for operating in safe mode & to perform clean boot is it necessary to create a backup of recovery disc?
    m asking dis cz i haven't created any backup in DVDs or PD....
    2014-04-18T07:16:49+00:00
    Hi Ashish,
    I would like to inform you that to boot the computer in safe mode or to perform clean boot, there is not need to create a recovery backup.
    Please try the methods suggested in my earlier post and reply us with the results to assist you further.
    2014-04-18T18:36:47+00:00
    hi sir,
    during safe mode operation the problem is not continuing......
    nw wat should i do?
    also i hv a software dll file fixer it shows dat i have 339 registry errors & shows that PC health is poor.....
    attaching its screenshot....
    kindly tell me what should i do in this case too????
    2014-04-19T14:13:34+00:00
    Hi Ashish,
    I would recommend you not to install any third party registry cleaners as it could harm your computer.
    Regarding the issue with Windows Explorer, I would suggest you to please follow the suggestions provided by me on April 17,2014.
    Reply us on the results to assist you further.
