How to fix a "X3DAudio1_7.dll is missing" error for DirectX11?
2014-02-16T03:17:57+00:00
I am currently running the 64 bit version of Windows 8 and I have attempted to install and play Skyrim on my computer. Whenever I try to launch Skyrim I get ad error message that says "X3DAudio.dll is missing from your computer. Reinstalling the program should fix this problem." I have uninstalled and reinstalled Skyrim 4 times in an attempt to fix the problem. I have also attempted to re install DirectX but it does not look like that is possible. I'm almost positive that this single error is the only thing keeping me from playing Skyrim. If someone could help me solve this issue I would be extremely grateful. Any suggestions?
2014-02-16T16:14:16+00:00
If you experience issues in which an application fails because of the missing file X3DAUDIO1_7.DLL, you may be able to resolve the failure by running the DirectX run-time package.
I would suggest you to download the the Runtime Package and then installing it.
http://www.microsoft.com/en-us/download/confirmation.aspx?id=8109
Also, you can diagnose basic problems with DirectX
http://windows.microsoft.com/en-ca/windows-8/diagnosing-problems-directx
Let us know if it helps. If the issue persists, we would be happy to help you further.
1000+ people found this answer helpful.
45 additional answers
    2016-12-17T19:17:36+00:00
    It may be that your game is looking for it in a different location...
    You might try to track that down and either copy the files to the location, or reinstall the Runtime to the needed location...
    2016-12-17T20:32:10+00:00
    ******@hotmail.com
    ***Personal information deleted by the moderator. Please see the Microsoft Community Frequently Asked Questions.***
    2017-01-11T17:43:57+00:00
    im using windows 10 and the program does not work every time i run it tells me to 'please refer to DXError.log and DirectX.log in your windows folder to determine problem.'
    2017-01-13T15:16:52+00:00
    Are you downloading the package before running it, or selecting "Run" at the download prompt ?
    Sometimes Windows can be funny with Permissions Issues... You could try copying the package to your C:\ folder before running ity, or extract it to a different location during the 1st step... Like your Desktop maybe, and try from there...
