How to fix a "X3DAudio1_7.dll is missing" error for DirectX11?
2014-02-16T03:17:57+00:00
I am currently running the 64 bit version of Windows 8 and I have attempted to install and play Skyrim on my computer. Whenever I try to launch Skyrim I get ad error message that says "X3DAudio.dll is missing from your computer. Reinstalling the program should fix this problem." I have uninstalled and reinstalled Skyrim 4 times in an attempt to fix the problem. I have also attempted to re install DirectX but it does not look like that is possible. I'm almost positive that this single error is the only thing keeping me from playing Skyrim. If someone could help me solve this issue I would be extremely grateful. Any suggestions?
2014-02-16T16:14:16+00:00
If you experience issues in which an application fails because of the missing file X3DAUDIO1_7.DLL, you may be able to resolve the failure by running the DirectX run-time package.
I would suggest you to download the the Runtime Package and then installing it.
http://www.microsoft.com/en-us/download/confirmation.aspx?id=8109
Also, you can diagnose basic problems with DirectX
http://windows.microsoft.com/en-ca/windows-8/diagnosing-problems-directx
Let us know if it helps. If the issue persists, we would be happy to help you further.
1000+ people found this answer helpful.
45 additional answers
    2017-06-19T03:06:40+00:00
    Hey, so I did this, and a TON of files are on my computer labeled with different dates and they require unzipping. What's the deal with this?
    2017-06-19T12:47:05+00:00
    Running the DXSETUP will unzip them and put them in the proper location..
    The first step is to Extract the download DirectX Runtime... Which is probably what you are seeing... The you need to do the actual setup\install...
    2017-10-05T13:56:37+00:00
    help me
    2017-11-10T22:43:58+00:00
    i cant play
