Windows 8.1 USB microphone volume is extremely low
2014-03-14T02:41:12+00:00
I have a Samson C01U USB mic. It is a plug-and-play microphone. There are no drivers for it. There is no firmware for it. You just plug it in, and it works.
This mic has always worked perfectly. When I used Windows 7, I set the volume level of it to about 40-50% and everything sounded crisp, clear, and loud. On Windows 8, it is inaudible unless I set the volume to 90% but even at that point it is not loud enough. Setting it to 100% results in a lot of noise in the background.
This is not the first time someone has brought this issue up as it is extremely common to everyone owning a USB plug-and-play mic:
http://www.overclock.net/t/1323451/windows-8-mic-issue
http://social.technet.microsoft.com/Forums/windows/en-US/2da97f80-f58b-4635-acbf-9dd7292ed752/microphone-very-low-volume?forum=w8itprohardware
http://answers.microsoft.com/en-us/windows/forum/windows\_8-hardware/low-usb-microphone-recording-volume-at2020/9528f797-65c8-4033-a4d6-39995cd0d074
Has there ever been a fix for this issue?
2014-07-31T00:46:56+00:00
Thank you for the reply.
As you have mentioned that you have checked the issue with other microphone but you still face this issue. We have already tried to uninstall and reinstall the drivers. I suspect this issue to be a hardware issue. Check the issue with a local technician.
121 additional answers
    2014-10-13T20:49:14+00:00
    Hello Marc,
    Thank you for your response.
    Yes, you may install an old driver on Windows 8.
    You may refer this article and check if it helps.
    Refer:
    Make older programs compatible with this version of Windows
    http://windows.microsoft.com/en-US/windows-8/older-programs-compatible-version-windows
    Note: Refer "Change compatibility settings manually" section in the above article.
    I hope this information helps.
    Thank you
    It's actually not a 'program' that I'm installing.  It's a Hardware Device, so the DRIVER needs to be changed.  I have the USBAUDIO.SYS file from my Windows 7 computer, how do I use this instead of the updated Windows 8.1 version?
    2014-10-16T15:12:09+00:00
    Hello Marc,
    I would suggest you to follow these steps to install "USBAUDIO.SYS".
    a. Press Windows + X keys and click device manager.
    b. Expand "Sound, video and game controllers".
    c. Right click sound device and click "Update driver software".
    d. Click "Browse my computer for driver software", click browse for finding "USBAUDIO.SYS" file.
    e. After the correct driver location path gets entered in the browse box, click "Next" and follow on-screen
    instructions.
    I hope this helps.
    Thank you
    2014-10-16T15:55:56+00:00
    After trying that, this is what I get:
    The best driver software for your device is already installed
    Windows has determined the driver software for your device is up to date.
    USB Adudio Device
    What happens if I want to force the older version on?
    I've tried clicking 'Let me pick from a list of device drivers on my computer' then click 'Have Disk...' it asks me for a .inf file, which I don't have since I copied the file from Windows 7.
    What other things can I try?
    2014-10-19T12:41:17+00:00
    Same issue here, after a quick research I found this is a common bug.
    This is really annoying, I've just bought my new USB mic and can't use it...
