I bit the bullet and bought a similar setup but am still dealing with audio level gain issues. AT2020 XLR and a Scarlette 2i2. The gain is positioned at about 3 o-clock, almost max, and in OBS I need to push the mic volume multiplier to 7.
This is what I was affraid of if I would buy a XLR mic like the at20202 with a Behringer Xenyx 302USB.
The signal still gets handled by Windows 8.1 eventually so the problem will still exists. Only because of the inbuild gain and the OBS mic boost you where able to get higher output volume. But this shouldn't be normally done like this. I think I'm going back
to Windows 7 again.
I can hardly believe that this problem really still exists in these Windows 8.1 versions. This is just stupid. What a waist of money for buying Windows 8.
