I've restarted the computer multiple times.
The Microphone (Samson C01U) has been connected to both USB 2.0 and USB 3.0 Ports, the issue persists no matter what port I connect it to.
I have used multiple cables, including brand new cables.
Hardware troubleshooter does not find any issue.
If I pass the USB port via Virtualbox to a windows 8 instance, I get the same issue, if I pass it via virtualbox to a windows 7 instance, I do not get this issue. I believe that this therefore points to there being an issue with the windows 8 USB audio drivers,
which will need a fix from Microsoft to resolve.
