There may be an issue with the O2 drivers.
Can you provide a recent dump file?
I use readyboost on my pc because it improves the speed of some the games I play (Battlefield 4, in particular). I have been using a 16 Gb. USB Flash drive since 2010 without any problem. But I recently added a 32 Gb. XD (SD) card to use for readyboost. I can access the card fine, and chkdsk says there are no errors, but since I have started using the card, I keep getting random 0x19 BSOD stop errors. the parameter is 0x21. I do not know what to do next or why readyboost is causing this error. it goes away when I stop using the 32Gb card. the full error is:
The computer has rebooted from a bugcheck. The bugcheck was: 0x00000019 (0x0000000000000021, 0xfffffa8010f19000, 0x0000000000001030, 0xb03c3740a81a7de7). A dump was saved in: C:\windows\Minidump\081814-32292-01.dmp. Report Id: 081814-32292-01.
I suspect readyboost is the cause of the issue, because the only difference in conditions between when it does and it does not happen is, is the use of the 32Gb card. I know that there is a 32Gb limit to the size of the memory card I can use. but using the max size should not be causing any issues
the most recent dump I have is the one I posted. My system has not yet BSOD on me. I have been refraining from doing anything thatr might put a strain (however small) on the system (like gaming). I will fire up BF4 later today to see how my system handles it.
This is the first time I have ever used the SD card slot on my PC, so it is very possible that there is an issue with the O2 drivers.
oops.... just checked whocrashed..... looks like last bsod was the 23rd will post link once dump is uploaded
just noticed there is a discrepancy between the dates and times shown on the dump files in whocrashed and the dump files themselves. the files says the 22nd is when they were created, so it looks like you may already have access to the dump file.
just checked previous post....that was from 21.... will upload new dump
my system finally had another 0x19 bsod again. windows is still in clean boot state. I will upload the dumps tomorrow morning
Hello Cybot,
Thank you for your reply, appreciate the time taken by you in keeping us updated on the status of the issue.
It’s unfortunate that your computer went to BSOD again even after so much of troubleshooting. Please post the system error logs as per your convenience, we’ll review the logs to identify the actual cause of this issue and get this problem resolved.
We’ll be glad to assist you further.
