Error code 8024A008 when trying to check for updates
2013-10-18T15:07:22+00:00
Hey, I just upgraded my computer from windows 8 to windows 8.1. After the installation I tried to run the Windows update and after sever minutes of checking for updates the following error occurred "8024A008".  I tried several methods to solve this, first of all I restarted the computer but nothing changed, then I ran the "Windows Update Diagnostic" tool with no luck either. I'd appreciate any advice on how to solve this problem. Thanks a lot!
2013-11-02T13:05:54+00:00
Look at the bottom of this thread:
http://social.technet.microsoft.com/Forums/windows/en-US/afc7f693-f742-402f-b513-063989b79c2f/windows-81-enterprise-windows-updates
http://gallery.technet.microsoft.com/scriptcenter/2d191bcd-3308-4edd-9de2-88dff796b0bc
1.)  Copy the whole module folder (after unzipping) to %WINDIR%\System32\WindowsPowerShell\v1.0\Modules
2.) Start up PowerShell ISE as admin from admin tools
3.) Set-ExecutionPolicy RemoteSigned
4.) Import-Module PSWindowsUpdate
5.) Get-WUInstall
6.) The rest should be automated with some prompts
After Reboot
follow the instructions to run the PowerShell script and it will force a Windows Update. Make sure you follow the instructions in the second relevant post:
This is a great solution! I just tested it and I only had one small issue. "Set-ExecutionPolicy RemoteSigned" was not sufficient in my case because the files were flagged as coming from another computer and were blocked when trying to import the module. Simple solution: copy the zip file locally and unblock the zip file BEFORE extracting the files, otherwise you have to unblock the files one by one. You can do that in the properties dialog of the file. You can also use "Set-ExecutionPolicy Unrestricted" but I do not suggest doing this.
If you want to execute without prompts, maybe to automate the process, you can execute:
Get-WUInstall -AcceptAll -IgnoreReboot
So great work by these Guys and a big thumbs down to Microsoft. I have run it successfully and it download 39 updates (including Office).
Many thanks to HenkelsGuy5
89 additional answers
    2013-10-29T01:31:25+00:00
    No it flickers up onto screen but poof! it's Gone!
    I haven't got but like three updates since 8.1! Defender I believe is but no more mine reads like that top example at start of conversation.
    2013-11-02T19:28:16+00:00
    Nice!! I tried it and worked perfect! Downloading 46 updates :) However it would be great if we had an official reply from Microsoft, it seems that a lot of people have the same problem.
    2013-11-02T20:28:54+00:00
    I agree - Microsoft need to fix this. Having to run a Powershell script to preform a Windows update is crazy.
    Ian
    2013-11-04T18:16:56+00:00
    OK, this worked as a workaround HOWEVER Windows update is still not in checking for update loop.
    Having to run PowerShell scripts to get updates is ... silly.
