Error code 8024A008 when trying to check for updates
2013-10-18T15:07:22+00:00
Hey, I just upgraded my computer from windows 8 to windows 8.1. After the installation I tried to run the Windows update and after sever minutes of checking for updates the following error occurred "8024A008".  I tried several methods to solve this, first of all I restarted the computer but nothing changed, then I ran the "Windows Update Diagnostic" tool with no luck either. I'd appreciate any advice on how to solve this problem. Thanks a lot!
2013-11-02T13:05:54+00:00
Look at the bottom of this thread:
http://social.technet.microsoft.com/Forums/windows/en-US/afc7f693-f742-402f-b513-063989b79c2f/windows-81-enterprise-windows-updates
http://gallery.technet.microsoft.com/scriptcenter/2d191bcd-3308-4edd-9de2-88dff796b0bc
1.)  Copy the whole module folder (after unzipping) to %WINDIR%\System32\WindowsPowerShell\v1.0\Modules
2.) Start up PowerShell ISE as admin from admin tools
3.) Set-ExecutionPolicy RemoteSigned
4.) Import-Module PSWindowsUpdate
5.) Get-WUInstall
6.) The rest should be automated with some prompts
After Reboot
follow the instructions to run the PowerShell script and it will force a Windows Update. Make sure you follow the instructions in the second relevant post:
This is a great solution! I just tested it and I only had one small issue. "Set-ExecutionPolicy RemoteSigned" was not sufficient in my case because the files were flagged as coming from another computer and were blocked when trying to import the module. Simple solution: copy the zip file locally and unblock the zip file BEFORE extracting the files, otherwise you have to unblock the files one by one. You can do that in the properties dialog of the file. You can also use "Set-ExecutionPolicy Unrestricted" but I do not suggest doing this.
If you want to execute without prompts, maybe to automate the process, you can execute:
Get-WUInstall -AcceptAll -IgnoreReboot
So great work by these Guys and a big thumbs down to Microsoft. I have run it successfully and it download 39 updates (including Office).
Many thanks to HenkelsGuy5
89 additional answers
    2013-10-25T22:29:10+00:00
    I just installed Win 8.1 , and I got the 8024A008 error code when I tried to install updates. I
    had update set to check for updates, but just let me know about them. I changed the setting
    to automatic updates and they all took off, downloading about 6 updates.
    I tried changing update settings & back again, but it didn't work for me -- 2 computers still have the same error code, nothing in these forums has fixed it yet
    Thx
    2013-10-27T11:30:49+00:00
    I have the same issue - and nothing seems to solve it.  Laptop is in OOBE mode - Windows Updates are stuck on "Checking for Updates..." but really I have two errors in my WindowsUpdate.log:
    • "Windows OOBE is still in progress"
    • "Failed to find updates with error code 8024a008"
    No idea how to fix this to get updates working again.
    2013-10-27T16:51:50+00:00
    Exactly the same problem on an HP EliteBook. Seems to affect quite a few people who upgraded from Win 8.0 to 8.1 using the .iso. This has been going on for a few weeks so please sort it out Microsoft. I have searched the web and no solutions so far.
    2013-10-27T18:15:02+00:00
    --BTW Mine wasn't with the .iso, but through the windows store
