Error code 8024A008 when trying to check for updates
2013-10-18T15:07:22+00:00
Hey, I just upgraded my computer from windows 8 to windows 8.1. After the installation I tried to run the Windows update and after sever minutes of checking for updates the following error occurred "8024A008".  I tried several methods to solve this, first of all I restarted the computer but nothing changed, then I ran the "Windows Update Diagnostic" tool with no luck either. I'd appreciate any advice on how to solve this problem. Thanks a lot!
2013-11-02T13:05:54+00:00
Look at the bottom of this thread:
http://social.technet.microsoft.com/Forums/windows/en-US/afc7f693-f742-402f-b513-063989b79c2f/windows-81-enterprise-windows-updates
http://gallery.technet.microsoft.com/scriptcenter/2d191bcd-3308-4edd-9de2-88dff796b0bc
1.)  Copy the whole module folder (after unzipping) to %WINDIR%\System32\WindowsPowerShell\v1.0\Modules
2.) Start up PowerShell ISE as admin from admin tools
3.) Set-ExecutionPolicy RemoteSigned
4.) Import-Module PSWindowsUpdate
5.) Get-WUInstall
6.) The rest should be automated with some prompts
After Reboot
follow the instructions to run the PowerShell script and it will force a Windows Update. Make sure you follow the instructions in the second relevant post:
This is a great solution! I just tested it and I only had one small issue. "Set-ExecutionPolicy RemoteSigned" was not sufficient in my case because the files were flagged as coming from another computer and were blocked when trying to import the module. Simple solution: copy the zip file locally and unblock the zip file BEFORE extracting the files, otherwise you have to unblock the files one by one. You can do that in the properties dialog of the file. You can also use "Set-ExecutionPolicy Unrestricted" but I do not suggest doing this.
If you want to execute without prompts, maybe to automate the process, you can execute:
Get-WUInstall -AcceptAll -IgnoreReboot
So great work by these Guys and a big thumbs down to Microsoft. I have run it successfully and it download 39 updates (including Office).
Many thanks to HenkelsGuy5
89 additional answers
    2014-02-01T23:33:01+00:00
    Did you skip any steps or reboots? It wasn't working for me until I rebooted and ran the troubleshooter. I also tried manually running C:\Windows\System32\oobe\msoobe.exe which didn't work.
    Before I did the sysprep oobe I ran the command found at the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\Setup\FirstBoot\PostOOBE
    It didn't seem to do anything so I omitted it from the above steps.
    Can you post the values for everything under:
    HKEY_LOCAL_MACHINE\SYSTEM\Setup\Status
    2014-02-02T15:14:35+00:00
    Hey focal, I tried your solution but I can't get past the 1st step. When I ran the following command "%systemroot%\System32\Sysprep\sysprep.exe /oobe" an error occured.
    Then, I tried the step 1b but after I made the necessary changes and reboots the above error remains. Any idea why?
    2014-02-02T20:39:35+00:00
    Check the referenced log file. Look for any line that begins with an error message or warning:
    2014-02-01 13:52:04, Error      [0x0f0036] SYSPRP spopk.dll:: Sysprep will not run on an upgraded OS. You can only run Sysprep on a custom (clean) install version of Windows.
    Feel free to post the log if you need further help.
    2014-02-03T06:58:00+00:00
    Hello, here is the log file - I am getting the same error, as mentioned above(screenshot)
    2014-02-03 07:53:06, Info                  SYSPRP ========================================================
    2014-02-03 07:53:06, Info                  SYSPRP ===          Beginning of a new sysprep run          ===
    2014-02-03 07:53:06, Info       [0x0f004d] SYSPRP The time is now 2014-02-03 07:53:06
    2014-02-03 07:53:06, Info       [0x0f004e] SYSPRP Initialized SysPrep log at C:\WINDOWS\System32\Sysprep\Panther
    2014-02-03 07:53:06, Info       [0x0f0054] SYSPRP ValidateUser:User has required privileges to sysprep machine
    2014-02-03 07:53:06, Info       [0x0f007c] SYSPRP FCreateTagFile:Successfully deleted tag file C:\WINDOWS\System32\Sysprep\Sysprep_succeeded.tag
    2014-02-03 07:53:06, Info       [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'OOBE'
    2014-02-03 07:53:06, Info       [0x0f00d7] SYSPRP WinMain:Pre-validing 'cleanup' internal providers.
    2014-02-03 07:53:06, Info                  SYSPRP RunExternalDlls:Running platform actions specified in action file for phase 3
    2014-02-03 07:53:06, Info       [0x0f00ba] SYSPRP SysprepSession::CreateSession: Successfully created instance with mount path C:, action file C:\Windows\System32\Sysprep\ActionFiles\Cleanup.xml, and mode <null>
    2014-02-03 07:53:06, Info                  SYSPRP SysprepSession::Validate: Beginning action execution from C:\Windows\System32\Sysprep\ActionFiles\Cleanup.xml
    2014-02-03 07:53:06, Info                  SYSPRP ActionPlatform::GetStringValue: Getting REG_SZ value SysprepMode under key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Setup\Sysprep
    2014-02-03 07:53:06, Info                  SYSPRP ActionPlatform::GetValue: Getting value SysprepMode under key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Setup\Sysprep
    2014-02-03 07:53:06, Warning               SYSPRP ActionPlatform::GetValue: Error from RegQueryValueEx on value SysprepMode under key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Setup\Sysprep; dwRet = 0x2
    2014-02-03 07:53:06, Info                  SYSPRP SysprepSession::CreateXPathForSelection: Sysprep mode in registry is <null>
    2014-02-03 07:53:06, Info                  SYSPRP ActionPlatform::GetStringValue: Getting REG_SZ value PROCESSOR_ARCHITECTURE under key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment
    2014-02-03 07:53:06, Info                  SYSPRP ActionPlatform::GetValue: Getting value PROCESSOR_ARCHITECTURE under key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment
    2014-02-03 07:53:06, Info                  SYSPRP SysprepSession::CreateXPathForSelection: Processor architecture in registry is AMD64
    2014-02-03 07:53:06, Info       [0x0f0080] SYSPRP ActionPlatform::LaunchModule: Found 'Sysprep_Clean_Validate_Opk' in C:\Windows\System32\spopk.dll; executing it
    2014-02-03 07:53:06, Error      [0x0f0036] SYSPRP spopk.dll:: Sysprep will not run on an upgraded OS. You can only run Sysprep on a custom (clean) install version of Windows.
    2014-02-03 07:53:06, Error      [0x0f0082] SYSPRP ActionPlatform::LaunchModule: Failure occurred while executing 'Sysprep_Clean_Validate_Opk' from C:\Windows\System32\spopk.dll; dwRet = 0x139f
    2014-02-03 07:53:06, Error                 SYSPRP SysprepSession::Validate: Error in validating actions from C:\Windows\System32\Sysprep\ActionFiles\Cleanup.xml; dwRet = 0x139f
    2014-02-03 07:53:06, Error                 SYSPRP RunPlatformActions:Failed while validating SysprepSession actions; dwRet = 0x139f
    2014-02-03 07:53:06, Error      [0x0f0070] SYSPRP RunExternalDlls:An error occurred while running registry sysprep DLLs, halting sysprep execution. dwRet = 0x139f
    2014-02-03 07:53:06, Error      [0x0f00d8] SYSPRP WinMain:Hit failure while pre-validate sysprep cleanup internal providers; hr = 0x8007139f
