Error code 8024A008 when trying to check for updates
2013-10-18T15:07:22+00:00
Hey, I just upgraded my computer from windows 8 to windows 8.1. After the installation I tried to run the Windows update and after sever minutes of checking for updates the following error occurred "8024A008".  I tried several methods to solve this, first of all I restarted the computer but nothing changed, then I ran the "Windows Update Diagnostic" tool with no luck either. I'd appreciate any advice on how to solve this problem. Thanks a lot!
2013-11-02T13:05:54+00:00
Look at the bottom of this thread:
http://social.technet.microsoft.com/Forums/windows/en-US/afc7f693-f742-402f-b513-063989b79c2f/windows-81-enterprise-windows-updates
http://gallery.technet.microsoft.com/scriptcenter/2d191bcd-3308-4edd-9de2-88dff796b0bc
1.)  Copy the whole module folder (after unzipping) to %WINDIR%\System32\WindowsPowerShell\v1.0\Modules
2.) Start up PowerShell ISE as admin from admin tools
3.) Set-ExecutionPolicy RemoteSigned
4.) Import-Module PSWindowsUpdate
5.) Get-WUInstall
6.) The rest should be automated with some prompts
After Reboot
follow the instructions to run the PowerShell script and it will force a Windows Update. Make sure you follow the instructions in the second relevant post:
This is a great solution! I just tested it and I only had one small issue. "Set-ExecutionPolicy RemoteSigned" was not sufficient in my case because the files were flagged as coming from another computer and were blocked when trying to import the module. Simple solution: copy the zip file locally and unblock the zip file BEFORE extracting the files, otherwise you have to unblock the files one by one. You can do that in the properties dialog of the file. You can also use "Set-ExecutionPolicy Unrestricted" but I do not suggest doing this.
If you want to execute without prompts, maybe to automate the process, you can execute:
Get-WUInstall -AcceptAll -IgnoreReboot
So great work by these Guys and a big thumbs down to Microsoft. I have run it successfully and it download 39 updates (including Office).
Many thanks to HenkelsGuy5
89 additional answers
    2013-12-02T07:05:58+00:00
    Changes back to 1.
    Same as before.
    2013-12-02T09:32:00+00:00
    I have been trying all the possible solutions yet i havent solve this problem.
    Windows Update is not working
    I recently Renewed the PC ( Format )
    Then some updates were installed but there are 32 left and cant install them
    When i try to download it says " Downloading 0 kb %0 finished " and this is not changing, i did my best
    So please help me solve this
    Thank you !
    TuGoCaN
    2013-12-06T01:39:29+00:00
    Exact same problem here. I updated to 8.1 not realizing all the issues. I'm unable to update or go back to 8.0. I've attempted the registry edit listed above but the value always reverts to a 1.
    2013-12-06T09:11:56+00:00
    The IsOOBEInProgress key is set to 1 by running Windows Update.
    If you enable verbose logging for Windows Update, run Windows Update and open WindowsUpdate.log, you will see that Windows Update sets this value :-
    "Setting 'Is OOBE In Progress' flag to 1"
    To turn on verbose logging, add the "Trace" registry key with the two values shown:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Trace
     Value name: Flags
     Value type: REG_DWORD
     Value data: 00000007
     Value name: Level
     Value data: 00000004
    This registry key turns on extended tracing to the %systemroot%\Windowsupdate.log file. Additionally, this registry key turns on an extended tracing to any attached debuggers.
    I suggest you remove the "Trace" key after testing, or rename it to "Trace old" etc.
    As ever, take care and back-up the Registry before making changes.
    I couldn't see anything in the extended WindowsUpdate.log file that would help solve this problem, but perhaps it will help someone more knowledgeable?
