How to remove $RECYCLE.BIN & System Volume Information from Each partition
2013-10-12T13:02:59+00:00
My windows 8.1 Pro (final release) infected with $RECYCLE.BIN & System Volume Information virus/malware in each partition.I have tried with windows Defender and Microsoft safety scannerto remove but windows Defender and Microsoft safety scanner not detect them.If i try to delete,it again appears.
Advice me how to remove " $RECYCLE.BIN & System Volume Information from each partition plea
<original title: How to remove $RECYCLE.BIN & System Volume Information virus from Each partition>
<moved from Virus and Malware>
2013-10-12T13:13:08+00:00
Typically $RECYCLE.BIN is for recycle bin allocation form your hard disk partition. and  System Volume Information bears the useful info regarding your volume.
These things are shown because hide protected system files tick is removed
Cant say it a virus effect or not..
If you feel like infected, much better to take the assistance of antivirus software
Download hitman pro 3.7**(shareware and can be activated for 30 days free)**and have a full system scan.. http://www.surfright.nl/en
And/or
use malwarebyte have a full system scan http://www.malwarebytes.org/products/malwarebytes_free/
After verifying , you can just make them invisible by doing this...
Note:- Optional/additional info -----(You DON'T have to run below to fix the problem )
Any folder and its content can be made shown as a recycle bin using a desktop.ini
Normally within this desktop.ini u can see.
[.ShellClassInfo]
CLSID={645FF040-5081-101B-9F08-00AA002F954E}
LocalizedResourceName=@%SystemRoot%\system32\shell32.dll,-8964
open a command prompt run as administrator
https://technet.microsoft.com/en-us/library/cc947813%28v=ws.10%29.aspx?f=255&MSPPError=-2147217396
change the the folder attrattributesre desktop.ini is kept using
attrib +a +s +h +r "folder" \* /d /s
you will see a recyclear bin folder
45 additional answers
    2015-06-05T09:43:00+00:00
    I am facing the same problem and when I write your following cmd code so I get this :
    please help mee
    Waiting for your valuable reply...........................
    Certainly you don't need to run this.. Use malware scans and windows default hide options. command line thing is just for extra information / illustration purpose.
    2015-06-06T08:08:25+00:00
    Hi Hetti,
    Pls tell me what to do to this thing that these disappear from my computer.
    pls dont tell me to hide those because if i will do then all my video files will be hidden also.
    pls help me out.
    waiting for your helpful reply..........
    cheers,
    deepan
    2015-06-06T14:49:19+00:00
    Hi Hetti,
    pls help me out.
    cheers,
    deepan
    What is the exact path/location of your video files?
    2015-06-06T17:47:12+00:00
    Hi Hetti,
    D:\Movies"name of movies".mkv
    My movie file paths like this.
    when i tried to move them then it shows:-
    The file properties are as follows:-
    i make them read only otherwise they are really hidden and i can't see them.
    Pls help me out...
    waiting for your reply.
    cheers
    Deepan
