How to remove $RECYCLE.BIN & System Volume Information from Each partition
2013-10-12T13:02:59+00:00
My windows 8.1 Pro (final release) infected with $RECYCLE.BIN & System Volume Information virus/malware in each partition.I have tried with windows Defender and Microsoft safety scannerto remove but windows Defender and Microsoft safety scanner not detect them.If i try to delete,it again appears.
Advice me how to remove " $RECYCLE.BIN & System Volume Information from each partition plea
<original title: How to remove $RECYCLE.BIN & System Volume Information virus from Each partition>
<moved from Virus and Malware>
2013-10-12T13:13:08+00:00
Typically $RECYCLE.BIN is for recycle bin allocation form your hard disk partition. and  System Volume Information bears the useful info regarding your volume.
These things are shown because hide protected system files tick is removed
Cant say it a virus effect or not..
If you feel like infected, much better to take the assistance of antivirus software
Download hitman pro 3.7**(shareware and can be activated for 30 days free)**and have a full system scan.. http://www.surfright.nl/en
And/or
use malwarebyte have a full system scan http://www.malwarebytes.org/products/malwarebytes_free/
After verifying , you can just make them invisible by doing this...
Note:- Optional/additional info -----(You DON'T have to run below to fix the problem )
Any folder and its content can be made shown as a recycle bin using a desktop.ini
Normally within this desktop.ini u can see.
[.ShellClassInfo]
CLSID={645FF040-5081-101B-9F08-00AA002F954E}
LocalizedResourceName=@%SystemRoot%\system32\shell32.dll,-8964
open a command prompt run as administrator
https://technet.microsoft.com/en-us/library/cc947813%28v=ws.10%29.aspx?f=255&MSPPError=-2147217396
change the the folder attrattributesre desktop.ini is kept using
attrib +a +s +h +r "folder" \* /d /s
you will see a recyclear bin folder
45 additional answers
    2016-08-15T11:14:26+00:00
    THANKS Hetti for warning me and for giving me that links.
    Now my pc is just working awesome thanks for your help.
    I just deleted the drive letter associated to system reserved and now it's not showing up
    thanks
    cheers!
    Deepan
    2016-10-16T19:35:17+00:00
    You NEED NOT TO DO THIS ALL JUST DO ONE THING
    OPEN COMMAND PROMT AS ADMINISTRATOR
    TYPE
    rd/s/q c:$RECYCLE.BIN
    rd/s/q d:$RECYCLE.BIN
    rd/s/q e:$RECYCLE.BIN
    CHANGE ONLY DRIVES AND RUN THIS COMMANDS LIKE C DRIVE, D DRIVE OR E DRIVE
    AND EVERYTHING IS OK
    IT WILL FORCEFULLY DELETE THAT VIRUS
    and if you do this twice means running the code again it will show you
    The system cannot find the file specified.
    means you did delete virus on first call now it no longer available hurry!
    2017-03-12T08:28:07+00:00
    Thank for support, My Problem is resolved, Are they harmful for PC.
    2017-07-13T11:52:54+00:00
    HELPFUL IT'S WORKED FOR ME,ERASED MY ALL DOUBTS.
    T hese things are shown because hide protected system files tick is removed
