PC Screen flicker and freezes or BSOD mainly when playing games like WoW or D3
2014-09-18T11:54:47+00:00
So I bought my machine on January, everything good until like 2 months in it started Screen freezing with a really loud noise or random BSODs when playing either Battlefield, World of Warcraft or Diablo III.
I've tried every troubleshoot possible and no success.
The problems aren't stable, as it happens some days, and then some other days the games run smoothly and fine.
I'd really like to solve this problem, as it's somewhat annoying.
Thanks in advance, best regards
Luís
2014-09-19T14:31:21+00:00
I've recommended the removal of the software below because of their tendency to cause BSOD's
NTIOLib_X64.sys Wed Oct 20 02:45:49 2010 (4CBE901D)
NTIOLib_X64.sys Thu Oct 25 21:46:44 2012 (5089EB84)
Driver Description: MSI Afterburner driver (known BSOD issues with Windows) Also found to be a part of MSI Live Update 5
 I've also recommended removal of avgtpx64.sys, AVG Secure search. If your current installed version of MBAM is not the full version, please uninstall it and turn on Windows Defender
Neither of these recommendations have been acted on. Please do so and test the system to see if these crashes re-occur.
Please upload a copy of your system information file. Click "start", type 'msinfo32", Click "file" at the top of the page, select "export" and give the file a name and click "save". Navigate to where the file was saved to, and upload the generated text file to a public folder on your OneDrive account and post the link here.
2014-09-19T14:26:58+00:00
Update Intel USB3 driver to version 3.0.0.34:
http://download.msi.com/dvr\_exe/intel\_usb30.zip
Update Intel Smart Connect Technology driver to version 5.0.10.2832:
http://download.msi.com/dvr\_exe/intel\_sct.zip
Update Realtek High Definition Audio driver to version 6.0.1.7293:
http://download.msi.com/dvr\_exe/realtek\_hd\_audio.zip
Update Killer Network driver to version 1.1.42.1045:
http://download.msi.com/dvr\_exe/Killer\_network\_win78.zip
Update Razer Naga drivers to version 1.18.15:
http://drivers.razersupport.com/index.php?\_m=downloads&\_a=viewdownload&downloaditemid=861&\_m=downloads&\_a=viewdownload&downloaditemid=861
Download the driver and copy it to a folder on your desktop. Write down the path to the folder. If the driver has been zipped you will need to right click on the file and extract to your folder.
Next type Device Manager in the Search box above the Start button and press ENTER. Locate and right click on the device and select Properties. Click on the Driver tab and the Update Driver button. Click on “Browse my computer for driver” and click the Browse button. Type in the Search box the file path to your folder and click on Next. The system should find the driver in your folder and update. If it does not find the driver recheck that the driver is not zipped.
Please advise the chipset installed version:
http://www.tomshardware.co.uk/forum/209590-30-which-chipset-driver-version-have#
When you have updated all drivers please restart your computer, allow 30 minutes for the system to run before uploading further information so that the impact of making changes can become apparent.
Please provide an updated copy of your System Information file. Type System Information in the Search Box above the start Button and press the ENTER key (alternative is Select Start, All Programs, Accessories, System Tools, System Information). Select File, Export and give the file a name noting where it is located. Do not place the cursor within the body of the report before exporting the file. The system creates a new System Information file each time system information is accessed. You need to allow a minute or two for the file to be fully populated before exporting a copy. Please upload to your OneDrive (formerly Sky Drive), share with everyone and post a link here. Reports in normal mode preferred. Please say if the report has been obtained in safe mode.
Please upload and share with everyone copies of your System and Application logs from your Event Viewer to your OneDrive and post a link here.
To access the System log select Start, Control Panel, Administrative Tools, Event Viewer, from the list in the left side of the window expand Windows Logs and select System. Place the cursor on System, select Action from the Menu and Save All Events as (the default evtx file type) and give the file a name. Do the same for the Applications log. Do not provide filtered files. Do not place the cursor in the list of reports before selecting Action from the menu. Do not clear logs whilst you have a continuing problem.
62 additional answers
    2014-09-18T12:00:54+00:00
    Luis
    To be able to diagnose what might be causing your system to crash, we need the dump files. In an ideal situation, more than one file would be needed to establish a pattern so if you do have more than one, please upload them.
    Please refer to the link below for steps to retrieve, zip and upload them to the file sharing site like onedrive, google's "dropbox, etc.
    When you are done, make the folder public and share the link here.
    Blue Screen of Death (BSOD) Created by ZigZag3143 (MS - MVP)
    http://answers.microsoft.com/en-us/windows/wiki/windows\_other-system/blue-screen-of-death-bsod/1939df35-283f-4830-a4dd-e95ee5d8669d
    2014-09-18T12:13:05+00:00
    Thank you for the swift reply,
    Here follows the link to the Dump files:
    http://1drv.ms/ZrmkXn
    2014-09-18T14:22:45+00:00
    Luis
    *                        Bugcheck Analysis                                    *
    Use !analyze -v to get detailed debugging information.
    BugCheck D1, {fffff8800705f000, 2, 0, fffff88004bb6fa0}
    Unable to load image \SystemRoot\system32\DRIVERS\e22w7x64.sys, Win32 error 0n2
    *** WARNING: Unable to verify timestamp for e22w7x64.sys
    *** ERROR: Module load completed but symbols could not be loaded for e22w7x64.sys
    Probably caused by : e22w7x64.sys ( e22w7x64+19fa0 )
    You need to update your Killer Network Driver from your local MSI support. You can get an English language version here:
    http://uk.msi.com/support/mb/H87G43\_GAMING.html#down-driver&Win7 64
    You almost certainly have other motherboard drivers that need updating.
    Please download and run Driver View and upload a copy of the report it produces to your OneDrive. To get a report on all drivers select Edit, Select All followed by File, Save Selected Items.
    http://www.nirsoft.net/utils/driverview.html
    Please provide a copy of your System Information file. Type System Information in the Search Box above the start Button and press the ENTER key (alternative is Select Start, All Programs, Accessories, System Tools, System Information). Select File, Export and give the file a name noting where it is located. Do not place the cursor within the body of the report before exporting the file. The system creates a new System Information file each time system information is accessed. You need to allow a minute or two for the file to be fully populated before exporting a copy. Please upload to your OneDrive, share with everyone and post a link here. Please say if the report has been obtained in safe mode. The request for a copy of this file is additional to answering the question about make and model.
    Select Start, All Programs, Accessories, right click Command Prompt, and click Run as administrator from the drop down menu.. Type *cd* and press ENTER. Type "chkdsk c: /r" without the quotes and hit ENTER. Make sure you include the spaces indicated. Enter Y when asked whether you wish to run chkdsk on restarting the computer. Type exit, press the ENTER key and restart the computer.
    Please run System File Checker and say if it cannot fix corrupted files: http://support.microsoft.com/kb/929833
