Program is missing and need to reinstall mfc110u.dll
2013-10-04T19:58:34+00:00
Original title: mfc110u.dll
After cleaning up some programs in my computer I am getting the message that a "program is missing and need to reinstall--mfc110u.dll..
Is there a free download to reinstall this?
2017-06-03T09:23:57+00:00
Hi Jake,
The mfc110u.dll is a default file from your Windows. As an initial troubleshooting, we suggest that you perform System File Checker (SFC) scan by following the steps on this link about how to run the SFC tool. This is to scan for missing or corrupted data files and fix them.
Should you need further assistance, let us know.
47 additional answers
    2015-01-13T07:10:58+00:00
    ok
    2015-03-03T16:13:16+00:00
    The  mfc110u.dll is missing from my computer   I need to reinstall it
    2015-04-04T08:55:49+00:00
    Program hiányzik, és újra kell telepítenie mfc110u.dll hogy?
    2015-04-04T09:22:34+00:00
    Please refer to the post by RajithRon June 14, 2014 from the same thread.
    Or you may follow this link
    Do let us know if you need further assistance.
