Program is missing and need to reinstall mfc110u.dll
2013-10-04T19:58:34+00:00
Original title: mfc110u.dll
After cleaning up some programs in my computer I am getting the message that a "program is missing and need to reinstall--mfc110u.dll..
Is there a free download to reinstall this?
2017-06-03T09:23:57+00:00
Hi Jake,
The mfc110u.dll is a default file from your Windows. As an initial troubleshooting, we suggest that you perform System File Checker (SFC) scan by following the steps on this link about how to run the SFC tool. This is to scan for missing or corrupted data files and fix them.
Should you need further assistance, let us know.
47 additional answers
    2017-09-04T01:35:26+00:00
    i need reinstall . (mfc110u.dll)
    2017-11-27T13:34:52+00:00
    After cleaning up some programs in my computer I am getting the message that a "program is missing and need to reinstall--mfc100u.dll..
    2017-12-07T09:15:13+00:00
    same as question  missing mfc110u.dll
    2017-12-07T12:05:33+00:00
    The problem is solved by itself I think. May be it was temporary missed.Thank you
